I've imported some rasters by i.in.spotvgt..
I don't understand because the first attempt fail while the second is
ok. Any raster that I try to import, the result is the same. first
attempt=FAIL; second attempt=OK
1° ATTEMPT:
GRASS 6.2.2 (WGS84):~ > i.in.spotvgt
file=/home/alfredo/cartografia/satellite/V1KRNS10__19980521_NDVI__Europe/0001/0001_NDV.HDF
rast=19980521
Import SPOT VGT NDVI map...
A datum name wgs84 (WGS_1984) was specified without transformation parameters.
Note that the GRASS default for wgs84 is towgs84=0.000,0.000,0.000.
Projection of input dataset and current location appear to match.
Proceeding with import...
100%
CREATING SUPPORT FILES FOR 19980521
SETTING GREY COLOR TABLE FOR 19980521 (8bit, full range)
r.in.gdal complete.
Imported SPOT VEGETATION NDVI map <19980521>.
Remapping digital numbers to NDVI...
100%
WARNING: Your color rules do not cover the whole range of data!
(rules -1.000000 to 1.000000 but data 79921.984000 to
79921.984000)
Color table for [19980521] set to ndvi
Done.
2° ATTEMPT:
rast=19980521_2
100%
CREATING SUPPORT FILES FOR 19980521_2
SETTING GREY COLOR TABLE FOR 19980521_2 (8bit, full range)
r.in.gdal complete.
Imported SPOT VEGETATION NDVI map <19980521_2>.
100%
Color table for [19980521_2] set to ndvi
Done.
