On 27 October 2016 at 13:53, Moritz Lennert
<mlennert@club.worldonline.be <mailto:mlennert@club.worldonline.be>>
wrote:
On 27/10/16 12:51, James Duffy wrote:
On 27 October 2016 at 11:45, Moritz Lennert
<mailto:mlennert@club.worldonline.be>>> wrote:
Le 27 octobre 2016 12:35:14 GMT+02:00, James Duffy
<james.philip.duffy@gmail.com
<mailto:james.philip.duffy@gmail.com>
<mailto:james.philip.duffy@gmail.com>>>
a écrit :
>On 27 October 2016 at 11:08, Moritz Lennert
>wrote:
>> Le 27 octobre 2016 11:22:02 GMT+02:00, James Duffy <
<mailto:james.philip.duffy@gmail.com>>> a écrit :
>> >Hello,
>> >I'm trying to use i.segment.stats with GRASS 7.0.4 in
the osgeolive
>> >32bit
>> >operating system.
>> >Prior to using this tool I have successfully created my
segmented
>map
>> >using
>> >i.segment.
>> >When I try to execute the following command:
>> >i.segment.stats --overwrite --verbose
map=gp_seg_optimum@gp1 \
>rasters=gp_ortho.1@gp1,gp_ortho.2@gp1,gp_ortho.3@gp1,gp_ortho.4@gp1
>> >raster_statistics=min,max,mean,stddev,variance,sum \
>csvfile=/home/jpd205/Wales_GRASS/GarronPill/gp_seg_stats \
>> >separator=comma
>> >I get this error:
>> >Calculating geometry statistics
>> >ERROR: G_malloc: unable to allocate 4273800320 bytes of
memory at
>> > /tmp/tmpgzUtnA/r.object.geometry/main.c:129
>> This is coming from r.object.geometry.
>> What are your region settings (g.region -p) ? How many
segments do
>you
>> have ?
>GRASS 7.0.4 (GarronPill):~ > g.region -p
>projection: 99 (OSGB 1936 / British National Grid)
>zone: 0
>datum: osgb36
>ellipsoid: airy
>north: 208007.00931776
>south: 207952.59780698
>west: 200993.90853302
>east: 201097.28911076
>nsres: 0.00430914
>ewres: 0.00430914
>rows: 12627
>cols: 23991
>cells: 302934357
Are you sure 4mm is correct for the resolution ?
Yes. It's high resolution imagery from a drone.
What does r.info <http://r.info> <http://r.info> on
>> Try running I.segment.stats without requesting form
statistics.
>Running:
>separator=comma
Default is to do form statistics, so the above line also
does. I
have to admit that I don't know what happens when you give
an empty
parameter such as
area_measures= or area_measures=""
gp_seg_optimum give you ?
| Map: gp_seg_optimum Date: Thu Oct 27
06:45:57
2016 |
| Mapset: gp1 Login of Creator:
jpd205 |
GarronPill |
| DataBase:
/home/jpd205/Wales_GRASS |
| Title: ( gp_seg_optimum
| Timestamp:
none |
| Type of Map: raster Number of Categories:
0 |
| Data Type:
CELL |
| Rows:
12627 |
| Columns:
23991 |
| Total Cells:
302934357 |
| Projection: OSGB 1936 / British National
Grid |
| N: 208007.00931776 S: 207952.59780698 Res:
0.00430914 |
| E: 201097.28911076 W: 200993.90853302 Res:
0.00430914 |
| Range of data: min = 35 max =
133556294 |
Ok, I think I see at least part of the problem: in GRASS 7.0
i.segment numbers segments non sequentially, i.e. whenever a new
segment is created out of the merger of two existing segments, a new
id is assigned. In GRASS trunk (the development version) i.segment
is rewritten to, at the end, number all segments sequentially from 1
to the number of segments.
r.object.geometry allocates memory according to the new system. As
it says in the code:
/* REMARK: The following is only true if object ids are
continuously numbered */
n_objects = max - min + 1;
obj_geos = G_malloc(n_objects * sizeof(struct obj_geo));
So, one solution would be to use the development version of GRASS.
Another would be to run r.clump on the result of the segmentation in
order to renumber the segments before running it through
i.segment.stats.
This option seemed the most straightforward given my current setup. I
ran r.clump with diagnoal enabled, and the output looked good. It only
took 2mins to run.
I then proceeded with the original i.segment.stats command and got the
following:
Calculating statistics for raster gp_ortho.1@gp1
ERROR: G_realloc: unable to allocate 572000 bytes of memory at
raster/r.univar/r.univar_main.c:324
It looks like the tool got further, but is still getting stuck on
something...
