I wanted to try out the sentinel toolset, trying to follow :
https://training.gismentors.eu/grass-gis-workshop-jena/units/20.html
However, the i.sentinel extension seems to be missing i.sentinel.coverage:
https://wingrass.fsv.cvut.cz/grass84/addons/grass-8.4.0/
Any idea if that can be added?
Vishal
Hi Vishal,
(cc Martin who maintains the wingrass server)
Good catch.
On Tue, Aug 27, 2024 at 4:10 AM Vishal Mehta via grass-user
<grass-user@lists.osgeo.org> wrote:
There seems to be some issue on the wingrass server:
https://grass.osgeo.org/grass84/manuals/addons/
--> Windows log files
Basically all jobs fail with:
File "C:\Users\landamar\grass_packager\grass84\addons\db.join\scripts\db.join.py",
line 64, in <module>
import grass.script as grass
ModuleNotFoundError: No module named 'grass'
Needs to be investigated on the server (I don't have access) by Martin.
Best
Markus Neteler, PhD
https://www.mundialis.de - company
https://grass.osgeo.org - FOSS
https://neteler.org - freelancing & blog
Hi Vishal,
In any case, please notice that i.sentinel.download received significant changes lately given that sentinelsat was no longer maintained and Sentinel data was moved from the Copernicus Open Access Hub to the Copernicus Data Space Ecosystem. i.sentinel.download now depends on i.eodag extension and EODAG library [1,2]. So, since i.sentinel.coverage uses i.sentinel.download as I am realizing now, it will probably need to be reviewed at least.
I’m putting Hamed in cc here, as he was the GSoC contributor working on the updates.
Best,
Vero
[1] https://grass.osgeo.org/grass84/manuals/addons/i.eodag.html
[2] https://eodag.readthedocs.io/en/stable/
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
Hi again,
On Tue, Aug 27, 2024 at 10:07 AM Markus Neteler <neteler@osgeo.org> wrote:
Hi Vishal,
Update from Martin, who is currently traveling:
Addons for GRASS GIS 8.4.0 are OK:
(so, please get the ZIP file from there for these days, he's check
8.4.dev addons once back)
Best
Thanks Markus, Veronica,
Indeed yes, I had wondered about these changes and whether the not-so-old work flows would still work!
Best,
Vishal
Hi Vishal,
Yeah, sentinelsat has not received any updates for almost a year now, and given the move to a different archive, the old i.sentinel.download and tools using it, wouldn’t work anyway. Same happened with i.landsat.download, whose underlying library is no longer maintained.
We are currently preparing an email with details about the changes. In the meantime, you can go through Hamed’s final report: https://grasswiki.osgeo.org/wiki/GRASS_GSoC_2024_EODAG_Support#Final_Report
Vero
Hi Veronica, all,
How can I start using i.eodag? This is my system:
GRASS version: 8.4.0
Code revision: e49c044e62
Build date: 2024-07-28
Build platform: x86_64-w64-mingw32
GDAL: 3.9.1
PROJ: 9.4.0
GEOS: 3.12.2
SQLite: 3.45.1
Python: 3.12.4
wxPython: 4.2.1
Platform: Windows-10-10.0.19044-SP0
