I want to try the new i.svm.* modules, but I discovered the manuals are not online at https://grass.osgeo.org/grass84/manuals/full_index.html#i and the modules are grey in the GUI. I installed the libsvm-dev package and added --with-SVM to the conf instruction, but that didn’t work. I searched around but neither the wiki nor the html manual files have any hint about compilation with svm support. How should I specify the conf instruction?
Maybe GRASS main is not being compiled with svm support in the server and that is why manuals do not appear online?
Thanks in advance!
Vero
El mar, 12 mar 2024 a las 9:52, Veronica Andreo (<veroandreo@gmail.com>) escribió:
found it in the configure file in the source code: --with-libsvm
On Tue, Mar 12, 2024 at 3:10 PM Veronica Andreo via grass-user
I want to try the new i.svm.* modules, but I discovered the manuals are not online at https://grass.osgeo.org/grass84/manuals/full_index.html#i and the modules are grey in the GUI. I installed the libsvm-dev package and added --with-SVM to the conf instruction, but that didn't work. I searched around but neither the wiki nor the html manual files have any hint about compilation with svm support. How should I specify the conf instruction?
I can add it to the server compilation. But which library is needed?
It is missing from
grep -i svm REQUIREMENTS.md
thanks,
The library is LIBSVM, for Ubuntu it was libsvm-dev
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
On Tue, Mar 12, 2024 at 3:32 PM Veronica Andreo <veroandreo@gmail.com> wrote:
Ok, in Fedora:
dnf install libsvm-devel
Please someone may open a pul request (PR) to update REQUIREMENTS.md
accordingly.
hint: "Good first PR"
[1]
[1] https://github.com/OSGeo/grass/blob/main/CONTRIBUTING.md#first-time-setup
