[GRASS-user] Identification of projectiopn?
Hi
I have two shape files of which I do not know the projection (and it seems that the person I got them from does not know either…). The maps are from the Keurboom nature reserve area in South Africa (http://plak.co.za/moreinfo.php?id=347) and the two shp files have the folowing bounding boxes:
In layer spatial reference system units : xMin,yMin 21340.4,-3755528.75 : xMax,yMax 34244.9,-3749187.87
In layer spatial reference system units : xMin,yMin 17001.2,-3754438.15 : xMax,yMax 37019.9,-3743929.77
I know this is a guessing game, but it must be a common projection - the map datum is very likely (almost certainly) WGS84.
Any suggestions welcome,
Rainer
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer@krugs.de
Skype: RMkrug
That really is a guessing game, because even if someone finds the coordinates that the map could fit into, it still doesn’t mean that they’re correct. Do you have a reason to think that the datum is WGS84? I think South Africa probably uses a more accurate regional datum for local maps - that makes a lot more sense unless you’re working directly with web mapping applications or you want to use GPS data directly.
Isn’t there any metadata provided with the shapefiles? I didn’t know that it was possible to have a shapefile without any kind of spatial reference stored in the metadata. You could try making a location based on the shapefile as a georeferenced file.
Best,
Daniel
B.Sc. Daniel Lee
Geschäftsführung für Forschung und Entwicklung
ISIS - International Solar Information Solutions
Deutschhausstr. 10
35037 Marburg
Festnetz: +49 6421 379 6256
Mobil: +49 176 6127 7269
E-Mail: Lee@isi-solutions.org
Web: http://www.isi-solutions.org
Am 05.07.2011 12:59 schrieb “Rainer M Krug” <r.m.krug@gmail.com>:
Hi
Rainer
South Africa
Skype: RMkrug
Yes - everybody is using WGS84, because it comes from a GPS - and reprojection usually is to be avoided because it is difficult to understand (I am allowed this statement - I have lived in SA and really loved it there!).
Well - as far as I know, the projection info comes in a .prj file (missing) and the .shp file efectively contains the points, dbf the attribute table and the shx the spatial index - no metadata.
All the data I have is the data - no metadata.
Here is the output from ogrinfo:
$ ogrinfo kcla_boundary.shp
INFO: Open of kcla_boundary.shp' using driver ESRI Shapefile’ successful.
1: kcla_boundary (Line String)
rkrug@ecolmod:~/Documents/Projects/HakeaLandscape/trunc/GIS/locations/Keurboom/region$ ogrinfo -al kcla_boundary.shp
Layer name: kcla_boundary
Geometry: Line String
Feature Count: 1
Extent: (17001.174423, -3754438.151804) - (37019.926542, -3743929.774592)
Layer SRS WKT:
(unknown)
OGRFeature(kcla_boundary):0
ID (Integer) = 0
LINESTRING (36961.220524529955583 -3748802.374081357847899,34701.038833641323436 -3749477.493287727236748,30885.147667205979815 -3747804.371776290237904,26218.019240565823566 -3746336.721327661070973,21316.066742145034368 -3743929.774591909721494,19877.769302488635731 -3745749.661148209590465,18821.060979475769273 -3745544.19008540129289,17470.822566737107991 -3746160.603273825719953,17001.174423175834818 -3748362.078946769237518,21169.301697282135137 -3750152.612494096625596,24368.77967529331363 -3750181.965503069106489,26276.725258510985441 -3751855.087014506105334,28360.788895564135601 -3753234.678436217363924,30591.617577480181353 -3754438.151804093271494,32323.44510686238209 -3753674.973570805974305,27715.022698167384078 -3751708.321969643235207,27509.55163535932661 -3750739.672673548106104,30180.675451864066417 -3750035.200458206236362,34025.919627271992795 -3751737.6749786157161,37019.92654247511382 -3748861.080099302809685)
Rainer
Best,
Daniel
B.Sc. Daniel Lee
Deutschhausstr. 10
35037 Marburg
Hi
Rainer
South Africa
Skype: RMkrug
South Africa
Skype: RMkrug
Hi Rainer
I'm not sure where Keurboom nature reserve is, but South Africa uses
transverse Metacor. So it probablity one of the following projections, just
the +lon_0 changes.
+proj=tmerc +lat_0=0 +lon_0=25.00000000000003 +k=1 +x_0=0 +y_0=0 +ellps=WGS84
+towgs84=0,0,0,0,0,0,0 +units=m +datum=WGS84 +no_defs
+proj=tmerc +lat_0=0 +lon_0=27.00000000000003 +k=1 +x_0=0 +y_0=0 +ellps=WGS84
+proj=tmerc +lat_0=0 +lon_0=29.00000000000003 +k=1 +x_0=0 +y_0=0 +ellps=WGS84
+proj=tmerc +lat_0=0 +lon_0=31.00000000000003 +k=1 +x_0=0 +y_0=0 +ellps=WGS84
Lester
On Tuesday 05 July 2011 12:52:01 Rainer M Krug wrote:
Hi
that the person I got them from does not know either...). The maps are from
Rainer
coordinates that the map could fit into, it still doesn't mean that they're
that makes a lot more sense unless you're working directly with web mapping
there!).
A datum commonly used in South Africa is Hartebeeshoek94, another one
is the Cape Datum coordinate system. Some topographical maps for South
Africa use a CRS with datum Hartebeeshoek94 and come together with
instructions on how to set up your GPS to use this CRS, so you don't
get lost when hiking.
IOW, at least in South Africa datums other than WGS84 are common.
Isn't there any metadata provided with the shapefiles? I didn't know that
INFO: Open of `kcla_boundary.shp'
using driver `ESRI Shapefile' successful.
Feature Count: 1
Layer SRS WKT:
(unknown)
ID (Integer) = 0
Rainer
Best,
Daniel
B.Sc. Daniel Lee
Deutschhausstr. 10
35037 Marburg
Am 05.07.2011 12:59 schrieb "Rainer M Krug" <r.m.krug@gmail.com>:
> Hi
> seems
> from
> map
> Rainer
> Biology,
> South Africa
> Skype: RMkrug
South Africa
Skype: RMkrug
grass-user mailing list
grass-user@lists.osgeo.org
On 05/07/11 12:52, Rainer M Krug wrote:
Hi
seems that the person I got them from does not know either...). The maps
Next to Lester's precise suggestions, this would be my path of choice:
Search for Type='projected CRS' and Area='South Africe' here: http://www.epsg-registry.org/ and then see which of these seem to fit.
Moritz
