[GRASS-user] importing a vector, problem with duplicate column name: cat_
importing a vector either using v.import GUI or v.in.ogr, it tries to rename the column into <cat_>, but both already exist and it throws out an error.
Check if OGR layer <pt599000_4414000_class1> contains polygons…
Column name renamed to <cat_>
DBMI-SQLite driver error:
Error in sqlite3_prepare():
ERROR: Unable to create table: ‘create table pt599000_4414000_class1 (cat integer, cat_ integer, cat_ integer, NDVI double precision)’
ERROR: Unable to import […]
Is there a way to overcome this?
Thank you for any suggestion
Margherita Di Leo
On Thu, Aug 4, 2016 at 9:24 AM, Margherita Di Leo <diregola@gmail.com> wrote:
the column <cat> into <cat_>, but both already exist and it throws out an
error.
Check if OGR layer <pt599000_4414000_class1> contains polygons...
Column name <cat> renamed to <cat_>
ERROR: Unable to create table: 'create table pt599000_4414000_class1 (cat
integer, cat_ integer, cat_ integer, NDVI double precision)'
ERROR: Unable to import [..]
you can overcome this with the columns option of v.in.ogr.
Markus M
Margherita Di Leo
grass-user mailing list
grass-user@lists.osgeo.org
Markus,
On Thu, Aug 4, 2016 at 9:48 AM, Markus Metz <markus.metz.giswork@gmail.com> wrote:
error.
Thank you for your suggestion. Do I understand correctly that this will add a third column? If in my work flow I have to import-process-export multiple times, this will add a column every time unless I explicitly drop a column?
Margherita Di Leo
On Thu, Aug 4, 2016 at 10:06 AM, Margherita Di Leo <diregola@gmail.com> wrote:
Markus,
wrote:
> Hi,
> rename
> an
> error.
a third column?
The columns option does not add another column, it provides column
names: "List of column names to be used instead of original names,
first is used for category column"
Yes, or use the key option of v.in.ogr. With your vector you could use
v.in.ogr key=cat, then drop the cat_ column. The next time you
re-import the vector, use again the key option, this should avoid that
"categories are generated as unique values and stored in [in a newly
created] 'cat' column"
Markus M
Margherita Di Leo
On Thu, Aug 4, 2016 at 10:29 AM, Markus Metz <markus.metz.giswork@gmail.com>
column?
Genau. Thank you
Margherita Di Leo
... or just don't export it if you don't need the cat column:
https://grass.osgeo.org/grass72/manuals/v.out.ogr.html
-s Skip export of GRASS category ID ('cat') attribute
best
markusN
