I have a .jpg screenshot of a Google-Earth Pro view and see that r.in.gdal
supports that file format. However, I have no idea how to structure the
command line for the task.
On the GE view I recorded the geographic coordinates of four
readily-identifiable points and can put them in a v.in.ascii point file for
import
My web searches for the process of saving a GE view as an .kml file were
without success. That would be another option for importing the GE image and
using it as the background for additional layers outlining specific areas.
Pointers to appropriate modules is appreciated.
Rich
Hi Rich,
A maybe-easier workflow is to load QGIS with an XYZ Google Satellite base layer, then save to image *with a World File*. That should allow easy import into other tools. https://geogeek.xyz/how-to-add-google-maps-layers-in-qgis-3.html
On 2019-10-18 at 12:52 -07, Rich Shepard <rshepard@appl-ecosys.com> wrote...
import
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Ken,
Good idea. I know that qgis and saga gis can use GE images as raster
underlayers and haven't seen an example using grass. I'll look into learning
qgis.
Rich
On Fri, Oct 18, 2019 at 9:52 PM Rich Shepard <rshepard@appl-ecosys.com> wrote:
import
How about:
i.gcp - Manages Ground Control Points (GCPs) non-interactively.
https://grass.osgeo.org/grass7/manuals/addons/i.gcp.html
Best
On Sun, 20 Oct 2019, Markus Neteler wrote:
How about:
Markus,
That looks like a good suggestion. I appreciate it.
Rich
