[GRASS-user] Importing MrSID files
   A DRG file is in MrSID format with these files available: drg_s_or071.aux,
drg_s_or071.sid, drg_s_or071.sid.xml, drg_s_or071.sdw, and
drg_s_or071.sid.html.
   The accompanying .txt file tells me the projection is UTM Zone 10. To
create a new location for this map I need to specify the file holding the
projection information and select the correct format in the GUI's second
step.
   Which file should I use to inform the grass GIS of the MrSID projection?
Rich
   Never mind. I looked up the EPSG code and entered that directly.
Rich
    However, I'm not finding the correct file at which to point grass.
r.in.gdal fails because it cannot find any bands. My web searches on how to
import a MrSID file all point me to the r.in.gdal manual page and no example
there seems to apply to the files I have.
Suggestions?
Rich
From what I read, you should point to the .sid file. But check if your gdal is compiled with MrSID support. A gdalinfo on the file should inform you if your gdal install can handle such files
On Tue, Sep 20, 2016 at 4:07 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
However, I’m not finding the correct file at which to point grass.
Suggestions?
Rich
grass-user mailing list
grass-user@lists.osgeo.org
Daniel,
   Now that is really interesting. Running 'gdalinfo --formats' produces a
list that does not include MrSid, which explains why grass did not want to
import the .sid file. Time to recompile gdal.
Thanks for the information,
Rich
   I had an old version of gdal installed and just upgraded that to version
2.1.1; still no MrSid support. In the gdal wiki I found this information:
"MrSID driver needs LizardTech decoding software development kit (DSDK). It
is not free software, but you can download it without charge at
https://www.lizardtech.com/developer/ (you will have to register first). To
enable file creation capability you need encoding SDK (ESDK). You should
contact LizardTech to obtain it."
   For a single DRG it's not worth the hassle.
Rich
