The instructions in the GEM manual do not fit the files downloaded for
r.basin (Makefile description.html r.basin/ r.basin.py r.basin1.gif
r.basin2.gif). What must I do to make r.basin available for use with data in
-6.5svn?
Rich
-6.5svn?
Rich
why not using g.extension?
http://grass.osgeo.org/grass64/manuals/html64_user/g.extension.html
Helmut
best regards
Helmut
View this message in context: http://osgeo-org.1560.n6.nabble.com/Installing-r-basin-With-GEM-tp4687329p4687336.html
Helmut,
Now that I'm aware of it, I will.
Rich
On Wed, Apr 4, 2012 at 8:56 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
http://grass.osgeo.org/grass64/manuals/html64_user/g.extension.htmlNow that I'm aware of it, I will.
Were should we remove pointers to the moreover outdated GEM?
Markus,
The wiki? Or, remove that page and links to it.
Rich
On Wed, Apr 4, 2012 at 9:04 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Markus,
Rich,
I am managing some 10+ servers with some 1000+ pages ![]()
Please be specific, say, which URL(s)?
thanks
The manual page does not explain from which directory it should be run.
The module needs to run within GRASS, but if I let GRASS pick the location
and mapset the build fails for an inability to find the Makefile.
I think it should be run from the GRASS source code directory, but what
command should be used to start GRASS so the module is properly built and
installed?
Errors:
mkdir -p
/home/rshepard/grassdata/Washington-Kinross/buckhorn/.tmp/salmo/4500.0/dist.i486-slackware-linux-gnu/fonts
make: *** No rule to make target .basin', needed by
/home/rshepard/grassdata/Washington-Kinross/buckhorn/.tmp/salmo/4500.0/dist.i486-slackware-linux-gnu/scripts/r.basin'. Stop.
ERROR: Compilation failed, sorry. Please check above error messages.
Rich
Please be
Markus,
Main page:
<http://grass.osgeo.org/grass65/manuals/html65_user/gem/index.html>
Rich
On Wed, Apr 4, 2012 at 9:11 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
It can be run from anywhere in the GRASS session.
Errors:
mkdir -p
Stop.
The Makefile was simply broken. Fixed in r51262.
Please retry
g.extension r.basin
For me it works now.
On Wed, Apr 4, 2012 at 9:12 PM, Rich Shepard <rshepard@appl-ecosys.com> wrote:
Main page:
@devs: perhaps add a prominent note on top that g.extension is recommended?
Huh! I ran svn up and rebuilt the system before starting today's session.
Will do so again.
Please retry
g.extension r.basin
Will do ... and report the results.
Rich
Interesting. I am at revision 51262. However, the third try worked. Very
strange.
Rich
