[GRASS-user] Interpolation on a Grid
> Frank Aragona wrote:
>> I'd like to do an interpolation of xyz data points that
>> I have, and put the interpolated data on 100' x 100'
>> grid. So that each 100' x 100' square has an
>> associated elevation value. Any suggestions as to how best
>> to do this?
Hamish:
> depending on how many input points you have either:
> v.in.ascii, g.region res=100, v.surf.rst
> or for massive datasets (>1-3 million points):
> g.region res=100, r.in.xyz, r.to.vect, v.surf.rst
> choice of method and {r|v}.surf.* interpolation module are subject to
> nature of data & personal preference. see also r.surf.nnbathy in wiki
> addons. the modules' manual pages should help you decide.
Frank wrote:
But I'd like the interpolated surface to be a set of
100' x 100' vector grids, each 100 x 100 square with
a discrete elevation value. Is this possible?
after import & binning as a raster use v.mkgrid to make your 100x100 grid,
then use v.what.rast or v.rast.stats to give each square an elevation
value. or maybe r.to.vect is easier?
Hamish
