[GRASS-user] Is ther a quick way to install grass8.3.2 in Ubuntu Jammy?
Hiu everybody, with some update I’ve broken my installation of QGIS 3.38 and GRASS 7,8,7
Now it seems that qgis-grass-plugin requires grass 8.3.2 but the pachage is not available in ubuntugis…
I’m not (yet) enaough confindent to use GRASS outside QGIS and I really need a quick solution to have this stack working.
I’m testing a workflow that translates sea-polyogns digitized with some reference coastine so they can match another refernce coastline: scripting and topological editing is mandatory so GRASS GIS will be the right tool.
Thank-you very much for your support.
Amedeo Fadini
Pianificatore Territoriale
Iscritto all’albo della provincia di Treviso al n. 3100
www.amefad.it
cell 328 2671141
Hi Amedeo
We just released 8.4, and it is here. Basically, you install the repo, update and install grass, something like:
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo apt-get update
sudo apt-get install grass grass-gui grass-dev
Then, for the plugin, you can customize which grass version it uses: Plugins > GRASS > GRASS Options. Under General you can change the version used to whatever you have.
HTH, I’m not the most knowledgeable person about Ubuntu…
Vero
Amedeo Fadini
www.amefad.it
cell 328 2671141
Dra. Verónica Andreo
Investigadora Adjunta de CONICET
Instituto Gulich (CONAE - UNC)
Centro Espacial Teófilo Tabanera (CETT)
Falda del Cañete - Córdoba, Argentina
+54 3547 400000 int. 1153
https://veroandreo.gitlab.io/
Thank-you Veronica for the reply,
Yes I’ve already update to 8.4 but aptitude refuse to install qgis-plugin-grass
her is the apt output:
The following packages have unmet dependencies:
qgis-plugin-grass : Depends: grass832 but it is not installable
I think it’s a problem on qgis side, or maybe the ubuntugis repository needs to be aligned…
I’ve asked here too just in case someone else has the same environment.
Well It will be a good choice to learn using GRASS GIS from CLI :slight_smile:
Amedeo
Amedeo Fadini
www.amefad.it
cell 328 2671141
Amedeo Fadini
www.amefad.it
cell 328 2671141
Hi Amadeo,
that version of QGis is not available from Ubuntu-GIS, therefore you should not expect packages provided by that PPA to link correctly with QGis. Either you install the QGis-GRASS bridge from the same source you installed QGis, or you install everything from Ubuntu-GIS. Anything else will inevitably to lead to a messy package set-up at some point.
Regards.
Luís Moreira de Sousa
Mastodon: https://mastodon.social/@luis_de_sousa
URL: https://ldesousa.codeberg.page
Sent with Proton Mail secure email.
On Saturday, August 3rd, 2024 at 6:32 PM, Amedeo Fadini AF via grass-user grass-user@lists.osgeo.org wrote:
Amedeo Fadini
www.amefad.it
cell 328 2671141
Hi Luís,
On Tue, 06. Aug 2024 at 07:11:55 +0000, Luís Moreira de Sousa via grass-user wrote:
QGIS has packages based on ubuntugis (also latest not only ltr). But
https://www.qgis.org/resources/installation-guide/#note-4 applies.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden https://www.norbit.de
QGIS release manager (PSC) Germany IRC: jef on Libera|OFTC
Hi Amedeo,
On Sun, Aug 4, 2024 at 12:13 PM Amedeo Fadini AF via grass-user
and in addition, you can use the nice improved GRASS GIS GUI.
See here how it looks like:
https://grass.osgeo.org/learn/gallery/#user-interface
--> Click: View more
