Thanks Vaclav for your help with the python script running outside grass when location is predefined. I am using an example posted in the case of no existing location and the following error came up…
alassane@alassane-MS-7593:~/Programs/grass/pythongrass$ /home/alassane/Programs/grass/pythongrass/grass_noloc.py
File “/home/alassane/Programs/grass/pythongrass/grass_noloc.py”, line 62
else:
SyntaxError: invalid syntax
The program works when I comment the followings statements
define GRASS DATABASE
if sys.platform.startswith(‘win’):
gisdb = os.path.join(os.getenv(‘APPDATA’, ‘grassdata’)
else:
gisdb = os.path.join(os.getenv(‘HOME’, ‘grassdata’)
gisdb = os.path.join(os.getenv(‘/home/alassane/Data’, ‘grassdata’)
instruction do not work
Here is the posted code used… Again your help is appreciated.
Alassane
#!/usr/bin/env python
Python script to generate a new GRASS GIS 7 location simply from metadata
Markus Neteler, 2014
?? LINUX USAGE: First set LIBRARY SEARCH PATH
#export LD_LIBRARY_PATH=$(grass70 --config path)/lib
#python start_grass7_create_new_location_ADVANCED.py
some predefined variables
Linux
grass7bin = ‘grass70’
#myepsg = ‘4326’ # latlong
myepsg = ‘3044’ # ETRS-TM32, http://spatialreference.org/ref/epsg/3044/
#myfile = ‘/home/neteler/markus_repo/books/kluwerbook/data3rd/lidar/lidar_raleigh_nc_spm.shp’
myfile = ‘/home/alassane/Data/IPDSData/lc80400372013110lgn01_prod_ll.tif’
#myfile = r’C:\Dati\Padergnone\square_p95.tif’
import os
import sys
import subprocess
import shutil
import binascii
import tempfile
########### SOFTWARE
we assume that the GRASS GIS start script is available and in the PATH
query GRASS 7 itself for its GISBASE
startcmd = grass7bin + ’ --config path’
p = subprocess.Popen(startcmd, shell=True,
stdout=subprocess.PIPE, stderr=subprocess.PIPE)
out, err = p.communicate()
if p.returncode != 0:
print >>sys.stderr, ‘ERROR: %s’ % err
print >>sys.stderr, “ERROR: Cannot find GRASS GIS 7 start script (%s)” % startcmd
sys.exit(-1)
if sys.platform.startswith(‘linux’):
gisbase = out.strip(‘\n’)
elif sys.platform.startswith(‘win’):
if out.find(“OSGEO4W home is”) != -1:
gisbase = out.strip().split(‘\n’)[1]
else:
os.environ[‘GRASS_SH’] = os.path.join(gisbase, ‘msys’, ‘bin’, ‘sh.exe’)
Set GISBASE environment variable
os.environ[‘GISBASE’] = gisbase
define GRASS-Python environment
gpydir = os.path.join(gisbase, “etc”, “python”)
sys.path.append(gpydir)
else:
override for now with TEMP dir
gisdb = os.path.join(tempfile.gettempdir(), ‘grassdata’)
try:
os.stat(gisdb)
except:
os.mkdir(gisdb)
location/mapset: use random names for batch jobs
string_length = 16
location = binascii.hexlify(os.urandom(string_length))
mapset = ‘PERMANENT’
location_path = os.path.join(gisdb, location)
Create new location (we assume that grass7bin is in the PATH)
from EPSG code:
#startcmd = grass7bin + ’ -c epsg:’ + myepsg + ’ -e ’ + location_path
from SHAPE or GeoTIFF file
startcmd = grass7bin + ’ -c ’ + myfile + ’ -e ’ + location_path
print startcmd
print >>sys.stderr, ‘ERROR: Cannot generate location (%s)’ % startcmd
sys.exit(-1)
else:
print ‘Created location %s’ % location_path
Now the location with PERMANENT mapset exists.
Now we can use PyGRASS or GRASS Scripting library etc. after
having started the session with gsetup.init() etc
Set GISDBASE environment variable
os.environ[‘GISDBASE’] = gisdb
Linux: Set path to GRASS libs (TODO: NEEDED?)
path = os.getenv(‘LD_LIBRARY_PATH’)
dir = os.path.join(gisbase, ‘lib’)
if path:
path = dir + os.pathsep + path
else:
path = dir
os.environ[‘LD_LIBRARY_PATH’] = path
language
os.environ[‘LANG’] = ‘en_US’
os.environ[‘LOCALE’] = ‘C’
Import GRASS Python bindings
import grass.script as grass
import grass.script.setup as gsetup
Launch session and do something
gsetup.init(gisbase, gisdb, location, mapset)
say hello
grass.message(‘— GRASS GIS 7: Current GRASS GIS 7 environment:’)
print grass.gisenv()
do something in GRASS now…
grass.message(‘— GRASS GIS 7: Checking projection info:’)
in_proj = grass.read_command(‘g.proj’, flags = ‘jf’)
selective proj parameter printing
kv = grass.parse_key_val(in_proj)
print kv
print kv[‘+proj’]
print full proj parameter printing
in_proj = in_proj.strip()
grass.message(“— Found projection parameters: ‘%s’” % in_proj)
show current region:
grass.message(‘— GRASS GIS 7: Checking computational region info:’)
in_region = grass.region()
grass.message(“— Computational region: ‘%s’” % in_region)
do something else: r.mapcalc, v.rectify, …
Finally remove the temporary batch location from disk
print ‘Removing location %s’ % location_path
shutil.rmtree(location_path)
sys.exit(0)
