[GRASS-user] largest number of consecutive days where rainfall >1 mm
Dear grass user
I have daily rainfall strds
I would like to obtain a layer of the largest number of consecutive days where rainfall >1 mm
Do you have any suggestions on how to calculate this climate index using grass's time modules?
thank you very much
Ivan
Hi Ivan,
On Wed, Aug 17, 2022 at 9:07 AM Ivan Marchesini
<ivan.marchesini@gmail.com> wrote:
Dear grass user
May this script code help?
https://grasswiki.osgeo.org/wiki/Temporal_data_processing#How_to_count_consecutive_days_that_meet_a_certain_condition?
thank you very much
Ivan
Hi Markus
thank you
Yes I saw that algorithm but, if I'm not wrong, it does not fit with my needs. The calculation made returns the number of days, in a given interval (here week), that meets a certain condition. Not sure they are consecutive. As an example: if negative temperature occur in monday and thuesday and then in friday, saturday and sunday then the code count 5 for that week. In my opinion what we need is 3.
I hope I was enough clear
In any case it would be good to find a solution for this type of problem because these type of indexes are used for climate data analysis (e.g.: https://www.ecad.eu/download/millennium/millennium.php https://www.climdex.org/learn/indices/ )
thank you
Ivan
On 17/08/22 20:04, Markus Neteler wrote:
Hi Ivan,
Dear grass user
thank you very much
Ivan
Hi Ivan,
It does indeed count consecutive days meeting a condition per week. That’s what the [-1] means in the t.rast.algebra command, i.e., it is the temporal neighbourhood modifier. If you then want to get the largest weekly consecutive days meeting the condition within a month you can aggregate the “weekly_consecutive” time series with t.rast.aggregate granularity=“1 month” method=“maximum”
HTH,
Vero
El jue, 18 ago 2022 a las 14:42, Ivan Marchesini (<ivan.marchesini@gmail.com>) escribió:
Hi Markus
thank you
Yes I saw that algorithm but, if I’m not wrong, it does not fit with my
thank you
Ivan
Hi Ivan,
Dear grass user
grass’s time modules?
thank you very much
Ivan
grass-user mailing list
grass-user@lists.osgeo.org
Dear Veronica
thank you for your answer
I understand your point but I still believe that the code is not working properly for my aims
I try to explain myself with an example.
According to the example in the tutorial:
the first command creates a weekly mask based on my data (daily precipitation in 2021):
t.rast.aggregate input=test2021 output=weekly_mask basename=mask_week granularity=“1 week” method=count nprocs=10
The second command add to the weekly value (7) the value of the consecutive days in the week period
t.rast.algebra base=test_rr_maggiore_1mm expression=“test_consecutive_days_rr_maggiore_1mm = weekly_mask {+,contains,l} if(test2021 < 1 && test2021[-1] < 1 || test2021[1] < 1 && test2021 < 1, 1, 0)” nprocs=10
In the attached file
https://drive.google.com/file/d/1eusufL8JLysac0wLfWC6oub0IM79e-KO/view?usp=sharing
I show an extract of the the values of a given pixel in the study area.
In the first week the value of the map "test_consecutive_days_rr_maggiore_1mm is 10 (7 + 3). 7 is the weekly base. 3 is the number of times in which a rainy day is preceded [-1] or followed [+1] by another rainy day. This happen in 2021-01-05, 2021-01-09, 2021-01-10 (in fact 3 days).
What is not fitting my needs here is the fact that between the 2021-01-05 and 2021-01-09 there are other days without rainfall. Actually we have not 3 consecutive days in this week!! We have 2 consecutive days: 2021-01-09, 2021-01-10 and another rainfall day at the start of the week.
I would like to have, in this first week, the value of 9 (7+2) not 10 (7+3), because I’m interested in the annual maximum length of wet spell, in days.
I hope I was able to explain myself
Thank you again
Ivan
On 18/08/22 15:36, Veronica Andreo wrote:
Hi Ivan,
HTH,
Vero
Hi Markus
thank you
thank you
Ivan
Hi Ivan,
Dear grass user
thank you very much
Ivan
