[GRASS-user] LIDAR Data
Hi
There was a bug in grass that was caused by adding the mapset with the @
paramter to the map. From which date is your cvs version? The fix was
submitted to the cvs last friday.
You may find the message with the bug report I referred to in the email
archives. It is from Leonardo Lami, dating from 29.5.2007 - "grass 6.3 bug"
and following messages
Frank
Am Mittwoch, 6. Juni 2007 schrieb Dr. Manuel Seeger:
Hello again,
yesterday it was the laser day:
we have obtained huge airborne laserscanner data, and want to try out
the modules in GRASS.
after importing the xyz-data into vector-file we apply
v.lidar.edgedetection second step should be v.lidar growing. but it does
not work
GRASS 6.3.cvs (Morbach):~ > v.lidar.growing
input=morbach55156_edge@PERMANENT output=morbach55156_grow
input_first=morbach55156
database=/home/seeger/Documents/GRASSDATA/Morbach/PERMANENT/dbf/
driver=dbf tj=0.2 td=0.6
dbmi: Protocol error
ERROR: It was impossible open table
well, this is the error I get. I dont know how to handle with this.
Any suggestions?
Another question. How many points can be handled with grass and these
modules (or grass vector files in general)?
Manuel
(thanks for the first help with terrestrial laserscanning data, I will
go deeper into this!)
Softwaredienstleistungen
Frank Broniewski
Cloefstraße 76a
66693 Mettlach
Email: frank@geo-dienstleistung.de
WWW: http://www.geo-dienstleistung.de/
Telefon: 06865 / 911 040
Frank Broniewski ha scritto:
Hi
There was a bug in grass that was caused by adding the mapset with the @ paramter to the map. From which date is your cvs version? The fix was submitted to the cvs last friday.
Maybe that solution pointed out by Frank is correct, but anyway I've also submitted a patch to v.lidar.growing command. Now it works without db and driver parameters. I also change "input_first" to "first". It is still clear and it is shorter :slight_smile:
It should work now. I tested v.lidar.grow with my lidar datasets and it works perfectly. So, you should update your CVS local version.
It depends. Without topology, people at my group is able to work with more than 9 millions of points without problems. I know some people around here has worked with 25 millions of points.
With topology, it depends on your computer. We have 2GB RAM and 4GB swap, and we are able to work with up to 8 millions of points. After that it goes out of memory.
Anyway, v.lidar.* don't ask and don't build topology and this helps a lot. Unfortunately, some useful vector commands within grass make use of the topology. And
Roberto.
Roberto Antolín Sánchez
Politecnico di Milano – Polo Regionale di Como
(Laboratorio di Geomatica V2.8)
Via Valleggio, 11 – 22100 Como, Italy
tel: +39 031 332 7533 || fax: +39 031 332 7519
email: roberto.antolin@polimi.it
