[GRASS-user] LS faktor in r.watershed
Dear friends,
I am working with the r.watershed module in order to compute the LS Faktor for (R)evised-Universal-Soil-Loss-Equation. For this option in the module, I have to set the threshold for the minimum size of exterior watersheds. There are many options out there to compute the LS-factor, but I could not find the paper/report/… that describes the algorithm used in GRASS.
Revised Universal Soil Loss Equation for Western Rangelands (Weltz et al. 1987).
I want to understand why I need to set this threshold if I want r.watershed to compute the LS -factor. So if somebody could help me with:
a) the reference, so I can check by my self.
or
b) a short explanation why this parameter must be set.
By the way, I tested r.watershed with several thresholds (resulting in 1 big subbasin up to several hundreds) but the results for the Ls factor hardĺy changed.
Thanks in advance,
Stefan
On Wed, Dec 12, 2012 at 10:16 AM, Stefan Luedtke
<sluedtke@gfz-potsdam.de> wrote:
Dear friends,
the paper/report/.. that describes the algorithm used in GRASS.
1987).
or
The LS and S factor calculation is only done for cells that are not
streams. I guess the reason is that soil loss does not apply to
streams (rivers). Streams in turn are determined using the threshold
option: all cells receiving more than threshold accumulated surface
flow are regarded as streams. A reasonable threshold depends on 1) the
resolution of the DEM, 2) the characteristics of the area under
consideration, 3) the context of the analysis.
changed.
Because it should have changed only for cells that are streams / not
streams depending on the threshold.
HTH,
Markus M
Thanks in advance,
Stefan
grass-user mailing list
grass-user@lists.osgeo.org
Thanks a lot, that helped and made my day.
Stefan
<[sluedtke@gfz-potsdam.de](mailto:sluedtke@gfz-potsdam.de)> wrote:
> Dear friends,
> 1987).
> or
> changed.
HTH,
Markus M
> Thanks in advance,
> Stefan
> [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
> [http://lists.osgeo.org/mailman/listinfo/grass-user](http://lists.osgeo.org/mailman/listinfo/grass-user)
