We're preparing a field sampling program, and would like to determine
a minimum distance between samples to reduce/eliminate spatial
autocorrelation. I think a good approach would be to calculate a
mantel correlogram, and use the range of the correlogram as our
minimum sampling distance.
* Questions
1) is this a reasonable approach
2) if so, how best to do this?
* Details
We have a vector map with the point coordinates of several hundred
potential sampling sites, and ~ 10 raster layers with appropriate data
to test for spatial autocorrelation (WORLDCLIM, soils). I could do
something like the following, but I'm not sure if there's a simpler or
more appropriate approach:
1) extract the raster data for each point
2) save the data to csv; import into R
3) calculate the spatial distances between points, after projecting
the lat-long data into an appropriate scale (?)
4) calculate the climate distance using the WORLDCLIM data
5) use the 'mgram' function in the 'ecodist' package to calculate the
actual correlogram between the spatial distance and climate distance
Any suggestions on the approach or the methods would be welcome!
Use R. It includes Moran's I and Geary's C tests for
spatial-autocorrelation. Look like it has mantel too.
You'll probably need the sp, spdep and rgdal packages. You might also
want to use the Raster package to extract the sampling data, or you can
use spGRASS to tie the R and Grass together.
* Questions
* Details
Use R. It includes Moran’s I and Geary’s C tests for
You’ll probably need the sp, spdep and rgdal packages. You might also
We’re preparing a field sampling program, and would like to determine
Questions
Details
something like the following, but I’m not sure if there’s a simpler or
use the ‘mgram’ function in the ‘ecodist’ package to calculate the
You are right, I didn't read it that closely 1st time around. My point
was that all of it can be done in R, and there are geospatial specific
packages that have all the tests one might want. The bare minimum
interaction is via rgdal or spgrass to pull data over from existing
GRASS data sets. If the data isn't already in GRASS then rgdal one can
read the original files directly. No need to pass csv around. Of course
if it is in GRASS then you should have it all in the same projection
already anyways if you put it all into the same mapset/location.
I believe Tyler does plan on using R for the statistical analyses, but
using GRASS GIS in combination with R is the easiest path, I think.
Tom
* Questions
* Details
Thanks for your suggestions. It looks like the R Borg is continuing to assimilate procedures that once required specialty software. Time to learn some new packages!
Tyler
On March 11, 2014 1:08:10 PM EDT, Alex Mandel <tech_dev@wildintellect.com> wrote:
determine
* Questions
* Details
data
or
the
distance
I agree, there -IS- “No need to pass csv around” because using the R spgrass6 package, one can read/write GRASS vector and raster files directly from R, so there are no intermediate files. I do this “all the time” — incredibly powerful using GRASS & R together.
You are right, I didn’t read it that closely 1st time around. My point
GRASS data sets. If the data isn’t already in GRASS then rgdal one can
Questions
Details
Please consider to eventually add some short workflow here:
I can do that – how do I make example datasets of mine available (which I would prefer, instead of using SPEARFISH or one of the other common datastes)?
Tom
On Sat, Mar 15, 2014 at 3:10 PM, Thomas Adams <tea3rd@gmail.com> wrote:
Markus,
I can do that -- how do I make example datasets of mine available (which I
datastes)?
if not too big and if having an open data license we could host them
on an OSGeo server (incl. the GRASS server).
