[GRASS-user] manual page for addons
I'm using a grass script of my own (say script.sh) which is located in a separate directory pointed by GRASS_ADDON_PATH.
However, the graphical interface provided by g.parser does not show the corresponding manual page.
I have a script.sh.html in the same directory. ¿Should I put a copy in /usr/share/doc/grass-doc/html/?
¿Is there any other environment variable pointing to the add-on documentation?
Thanks!
ƒacu.-
2009/9/16 Facundo Muñoz <famuvie@alumni.uv.es>:
Yes.
documentation?
AFAIK that's not (yet?) available.
Thanks!
ƒacu.-
grass-user mailing list
grass-user@lists.osgeo.org
there may be something in William's extra ETC for frameworks magic.
Hamish
There was some discussion this summer in relation to g.extension about user-addon paths.
For user manual pages, see how I do it for OSX in macosx/app/build_html_user_index.sh. It's basically a copy of build_html_index.sh (used in compilation only) changed to build a user html index on startup, from a known path (not GRASS_ADDON_PATH). It's a bit clunky because the installed help index is static, so the user help index must be a separate index, and it's not possible to link to a user's home folder from the main index in html (because it's variable).
I think GRASS needs a more structured external addon path setup than the loose GRASS_ADDON_PATH (which only extends the env PATH). My GRASS_ADDON_ETC, and companion g.findetc is one step to this, but it doesn't say anything about help files.
Hamish
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Oh, look, I seem to have fallen down a deep, dark hole. Now what does that remind me of? Ah, yes - life."
- Marvin
