[GRASS-user] memory requirement of v.net.allpairs module (Markus Metz)
Dear users and developers,
v.net.allpairs return +ve distance for points in the backward direction of the vector and -ve value for points lying in the forward direction of the vector.
(I have posted a similar script earlier for this purpose. Which was written in bash script format.)
One can use these categories to sum up the areas (r.stream.basins) and calculate the cumulative area without creating individual raster maps ( thus, using hard disk space) for each point.
This module is pretty fast in calculating the distance.
However, from the moment, when it writes the values in database (sequential write , perhaps) , it’s a slow process.
In the reply , it was mentioned that all the information (from cat, to cat, distance ) is held in a temporary file. (reason for large swap space being used 160 gb)
Can’t we have a text file (from this temp file) instead of sequential database write for large vector sets. (for example, as those created by r.stats .)
The text file can be copied to database in few seconds. Whereas, this can take six month (145,000 * 145,000).
I have run it on smaller region and on an vector output of 11000 points (i.e. 11,000 * 11,000) ,it took approximately 12 hours to finish.
Can we have opinion of Dear Daniel Bundala ( the module developer ) on this.
Thanks.
On Wed, Dec 28, 2011 at 5:46 PM, <grass-user-request@lists.osgeo.org> wrote:
Send grass-user mailing list submissions to
grass-user@lists.osgeo.org
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body ‘help’ to
You can reach the person managing the list at
grass-user-owner@lists.osgeo.org
When replying, please edit your Subject line so it is more specific
than “Re: Contents of grass-user digest…”
Today’s Topics:
  1. Re: memory requirement of v.net.allpairs module (Markus Metz)
  2. Compile and install 6.4.2RC2 (Aldo Clerici)
  3. Re: Compile and install 6.4.2RC2 (Martin Landa)
Message: 1
Date: Tue, 27 Dec 2011 18:53:20 +0100
From: Markus Metz <markus.metz.giswork@googlemail.com>
Subject: Re: [GRASS-user] memory requirement of v.net.allpairs module
To: Pankaj Kr Sharma <pkscwc@gmail.com>
Cc: grass-user@lists.osgeo.org, grass-dev@lists.osgeo.org
Message-ID:
<CAG+h=FGPOU61d45cQVw0UczvGWGJmVLmYYtqaaFPiD7mK-iKhw@mail.gmail.com>
Content-Type: text/plain; charset=ISO-8859-1
On Sun, Dec 25, 2011 at 5:04 PM, Pankaj Kr Sharma <pkscwc@gmail.com> wrote:
Dear Developers and users,
On a small test region (11000x11000 cells), with a threshold of 1000sqkm,
r.stream.extract resulted in a stream vector network of 190 points and
lines. The v.net.allpairs generated a table of distances between each point
within 10 seconds on my home machine (only 4gb ram). I thought that I got
my solution for finding sub-basins of a very large area. (Please refer to my
earlier posts in this regard.)
On my work setup, (better machine, 16gb RAM , six cores), I followed this
routine:
  1. r.grow by one cell on area of interest. (It’s an important step. Thanks
    to Markus Metz for this tip.) Time taken by the module: approximately 2
    hours.
  2. r.stream.extract on my area of interest.(42000*42000 cells) with 100
    sq.km. as threshold (12345 in number of cells.)
Above you said that yourtest region was 11000x11000 cells, not
42000x42000 cells. Both r.grow and r.stream.extract will be
considerably faster if you adjust your computational region to your
test region.
Please note that the r.stream.extract module’s vector output was a
network of 1,45,000 (approx) points and lines.
Time taken by module: approximately 24 hours.
  1. Then I ran “v.net.allpairs” on this network. Now, v.net.allpairs is still
    running. Approximately, one week has elapsed.
    After three days, a message appeared on the console that says “writing data
    into the table”. After four days of this message, the progress bar is still
    without any colour. ( Which I consider as progress being less than one
    percent.)
The other thing which I noticed was the memory consumption. The module has
consumed 15.5 gb ram out of 16gb, thereafter it consumed 166gb of swap space
out of 500gb swap space available.( Earlier, I had kept complete one disk of
1 tb for swap.)
This sounds like bad news. v.net.allpairs keeps all categories,
all categories, and all distances from to in memory.
For 145000 network nodes, this would be about 320 GB. Assuming that
half of the features are lines and half of the features are points,
v.net.allpairs would require about 160GB of memory, plus some overhead
to handle the vector if you did not set the environment variable
GRASS_VECTOR_LOWMEM. Granted that you did not run v.net.allpairs with
the -a flag.
Why did you use v.net.allpairs at all on the stream network?
Markus M
Some of the answers for this response of the module, I have myself.
Like, the module has more calculations to do.
(145000145000)/(190190)~582410.
Still, as per my calculation of time required 58241010 seconds/(2460*60)~
6.75 days
And, I should have my postgres table ready for further calculations.
But, still there is no sign of any progress.
Is the time and memory being consumed by the module as per design and ok.
I can definitely sub-divide into basins and work further.
Message: 2
Date: Wed, 28 Dec 2011 12:46:17 +0100
Subject: [GRASS-user] Compile and install 6.4.2RC2
To: <grass-user@lists.osgeo.org>
Message-ID: <045901ccc556$4f6c51e0$ee44f5a0$@clerici@unipr.it>
Content-Type: text/plain; charset=“us-ascii”
I’m having troubles in compiling and installing grass6.4.2RC2 on Fedora 10.
I installed Python-2.7.2, wxPython-2.9.2.4, numy-1.6.1.
I run: ./configure --with-cxx --with-python=/usr/local/bin/python2.7-config
–with-wxwidgets=/usr/local/bin/wx-config
with the following output:
GRASS is now configured for: i686-pc-linux-gnu
Source directory: /home/clerici/GRASSprograms/grass-6.4.2RC2
Build directory: /home/clerici/GRASSprograms/grass-6.4.2RC2
Installation directory: ${prefix}/grass-6.4.2RC2
Startup script in directory: ${exec_prefix}/bin
C compiler: gcc -g -O2
C++ compiler: c++ -g -O2
Building shared libraries: yes
64bit support: no
OpenGL platform: X11
MacOSX application: no
MacOSX architectures:
MacOSX SDK:
Tcl/Tk NVIZ: yes
BLAS support: no
C++ support: yes
Cairo support: no
DWG support: no
FFMPEG support: no
FFTW support: yes
FreeType support: no
GDAL support: yes
GEOS support: no
GLw support: no
JPEG support: yes
LAPACK support: no
Large File support (LFS): no
Motif support: no
MySQL support: no
NLS support: no
ODBC support: no
OGR support: yes
OpenGL support: yes
PNG support: yes
PostgreSQL support: no
Python support: yes
Readline support: no
SQLite support: no
Tcl/Tk support: yes
wxWidgets support: yes
TIFF support: yes
X11 support: yes
Then: make
GRASS GIS compilation log
Started compilation: Wed Dec 28 12:22:59 CET 2011
Errors in:
No errors detected.
Finished compilation: Wed Dec 28 12:24:11 CET 2011
And su -c ‘make install’ that seems ok.
However when I run: grass64 -wxpython I have the following error message:
Cleaning up temporary files …
Starting GRASS …
ERROR: wxGUI requires wxPython. No module named wxversion
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
Where did I go wrong?
Many thanks in advance.
A. Clerici
Parma University
An HTML attachment was scrubbed…
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111228/d8363dca/attachment-0001.html
Message: 3
Date: Wed, 28 Dec 2011 13:16:29 +0100
Subject: Re: [GRASS-user] Compile and install 6.4.2RC2
To: Aldo Clerici <aldo.clerici@unipr.it>
Message-ID:
<CA+Ei1Ocvg1hBsjQNt_bPA7ys2pzWiDWDBFRuuo3KD-WBXZg2Aw@mail.gmail.com>
2011/12/28 Aldo Clerici <aldo.clerici@unipr.it>:
you need to install package which contains wxversion. On Debian
GNU/Linux it’s eg. python-wxversion.
Martin
Martin Landa <landa.martin gmail.com> * http://geo.fsv.cvut.cz/~landa
End of grass-user Digest, Vol 68, Issue 48
