[GRASS-user] Mosaic Images
Greetings!
When I try to mosaic landsat images(just one band) which belong to adjacent
path-rows they do not mosaic properly. It appears as in the attached
screenshot. I have tried changing the order of images but just the
overlapping image changed. I have tried r.patch as well as i.image.mosaic
with region encompassing both the scenes. However if I mosaic the same
images in ERDAS Imagine there are no issues. Mosaiced image will be simply
perfect except for brightness differences. ERDAS also provides options like
histogram matching to sort out such issues. So what is the way to mosaic
images in GRASS? Also is there any way to use specify options like
resampling, histogram matching in the process?
Thanks and regards,
Chethan S.
http://osgeo-org.1803224.n2.nabble.com/file/n6108043/mosaic.png
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mosaic-Images-tp6108043p6108043.html
belong to adjacent
attached
just the
i.image.mosaic
mosaic the same
way to mosaic
options like
[sorry about yahoo's linewrap]
the d.what.rast or the query tool to check to see if the black image
boundaries are in fact NULL, or if they are 0. If they are 0 use the
r.null module to set them to NULL, then try again.
Hamish
On Tue, Mar 8, 2011 at 10:45 AM, Hamish <hamish_b@yahoo.com> wrote:
belong to adjacent
attached
just the
i.image.mosaic
mosaic the same
way to mosaic
options like
As an alternative, you can use r.clump2 from GRASS-Addons
and flood-fill areas (here, the "black" boundary" using the
coordinate parameter.
