2014-10-15 1:54 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
Ing. Giuliano Urgeghe
Via Prunizzedda 61 - 07100 Sassari
giuliano.u@gmail.com
tel. 3283268186
Cerca di non inviarmi files .doc, .xls, .ppt, .dwg
Preferisco formati liberi.
Please try to avoid to send me .doc, .xls, .ppt, .dwg files.
I prefer free formats.
http://it.wikipedia.org/wiki/Formato_aperto
http://en.wikipedia.org/wiki/Open_format
On Tue, Oct 14, 2014 at 7:37 PM, Giuliano Urgeghe <giuliano.u@gmail.com> wrote:
Ciao Anna
problema risolto
usando ‘,’
I guess this means success:)
Best,
Anna
GRAZIE
2014-10-15 0:10 GMT+02:00 Giuliano Urgeghe <giuliano.u@gmail.com>:
just to say that I also tried with fs=‘,’
and I had the same error:
“output” non Š riconosciuto come comando interno o esterno,
un programma eseguibile o un file batch.
which module is contained in this response string?
tel. 3283268186
2014-10-14 23:19 GMT+02:00 Giuliano Urgeghe <giuliano.u@gmail.com>:
Hi Anna,
thanks for your interest
I checked
my fs in the input is ‘|’
the word ‘output’ in grass.run.command’s argument is not known
is an error in core.py? or is a bug in windows executing?
I don’t find solution
Bye
Giuliano
tel. 3283268186
2014-10-14 3:45 GMT+02:00 Anna Petrášová <kratochanna@gmail.com>:
tel. 3283268186
On Mon, Oct 13, 2014 at 5:53 PM, Giuliano Urgeghe <giuliano.u@gmail.com> wrote:
thanks for your help.
At moment I have another problem
in my script I have this line:
grass.run_command(‘v.in.lines’, overwrite=True, input = output_esond_txt , output = output_esond_gis, fs=‘|’)
grass.run_command(‘v.in.ascii’, overwrite=True, format= ‘point’, fs=‘|’, input = output_esond_txt, output = output_esond_gis )
output is:
Not sure, but could you try use different separator
grass.run_command(‘v.in.ascii’, overwrite=True, format= ‘point’, fs=‘,’, input = output_esond_txt, output = output_esond_gis )
or, since | is a default, not using it in the command at all?
grass.run_command(‘v.in.ascii’, overwrite=True, format= ‘point’, input = output_esond_txt, output = output_esond_gis )
Anna
why?
I have made many attempts whith grass6.4.2 grass6.4.3 grass6.4.4
in windows Vista
you know the problem?
thanks in advance
Giuliano
grass-user mailing list
grass-user@lists.osgeo.org
2014-10-13 7:43 GMT+02:00 Johannes Radinger <johannesradinger@gmail.com>:
It seems to raise an error related to the flag(s) you are specifying in oneof your grass modules you are using in your script. Flags in grass python scripts should be used like: flags=“a” or for two flags: flags=“ab”. Note this does not need a “-” like in the bash command.
Best,
/johannes
-------- Original message --------
Date: 13/10/2014 02:44 (GMT+01:00)
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] my first script
I have my first script in python for grass
but when I launch it on windows vista for grass 6.4.2 in quantum gis
I have this output:
File “C:\PROGRA~1\QUANTU~3\apps\grass\grass-6.4.2\etc\pyth
on\grass\script\core.py”, line 189, in run_command
ps = start_command(*args, **kwargs)
on\grass\script\core.py”, line 167, in start_command
args = make_command(prog, flags, overwrite, quiet,
verbose, **options)
on\grass\script\core.py”, line 124, in make_command
raise ScriptError(“‘-’ is not a valid flag”)
grass.script.core.ScriptError: “‘-’ is not a valid flag”
someone know this problem?
thanks in advance
Giuliano
