[GRASS-user] MySQL mysql.sock GRASS connection problem
Dear GRASS list,
I am having problems connecting to a local MySQL db from GRASS.
using the following commands i get the error below...
> db.connect driver=mysql database=dbname
> db.login user=user pass=password
> db.tables -p
DBMI-MySQL driver error:
Cannot connect to MySQL: Can't connect to local MySQL server through socket '/tmp/mysql.sock' (2)
A far as I was aware this is general error to do with some installations of MySQL placing mysql.sock somewhere else other than /tmp. I encountered this before when trying to connect another MySQL client (R) and easily solved the problem by editing the /etc/my.cnf file to contain the true [client] location of mysql.sock. GRASS seems to be ignoring the /etc/my.cnf file though and seems to be still trying to locate mysql.sock in /tmp. All my other MySQL clients don't have a socket problem. Does GRASS take its MySQL global configs from some other location? Is something else wrong? Any help would be greatly appreciated.
I'm running GRASS 6.2.1 courtesy of OpenOSX on Mac OSX 10.4.11 with MySQL 5.0.19.
Best wishes,
Mark
> db.tables -p
MySQL 5.0.19.
The MySQL driver never tries to force the use of a specific socket
path.
It connects using:
    res = mysql_real_connect ( connection, connpar.host, user, password,
                         connpar.dbname, connpar.port, NULL, 0);
[ http://trac.osgeo.org/grass/browser/grass/tags/release_20061212_grass_6_2_1/db/drivers/mysql/db.c ]
If you specify just a database name to db.connect, connpar.host will
be NULL, which will cause it to use a Unix-domain socket. The
unix_socket parameter is always NULL, which causes the client library
to use the default socket path.
[ http://dev.mysql.com/doc/refman/5.0/en/mysql-real-connect.html ]
Thanks for the information Glynn,
From the documentation, not specifying a host shouldn't matter as mysql is on localhost and even if i specify host=localhost the UNIX socket will still be used. I have tried specifying the port but still nothing. I can't understand how I can change the default behaviour from the client library. I guess my current level of experience isn't great enough yet.
I have done a work-around by creating symbolic link from the true mysql.sock to /tmp/mysql.sock. db.connection is working. If you have more specific alternative suggestions I'd be happy to hear them.
My MySQL installation is from MAMP. I know a lot of fellow students who are using or are about to use MAMP/GRASS/R etc. Would it be a good idea to modify the GRASS-MySQL connection to avoid socket issues like this? This is a debate for another list though. I'll post elsewhere.
Many thanks for your response,
Mark
db.tables -p
MySQL 5.0.19.
path.
It connects using:
