example:
http://bambi.otago.ac.nz/hamish/grass/screenshots/inlets_03_SurfSal_icw_big.pngsample data points are given with black diamonds. interpolation
must travel around islands and along channels.
ooh, that looks good. Very useful for interpolating data with faultlines,
I guess. However, quite the overkill for my little problem
by AA, do you mean like a 0 floor and 255 ceiling and depending
on how much vector line in the cell the output raster value
is somewhere in between (with length of cell diagonal == *1.0 ),
or is it still binary null || line_value but in a more smeary
way than normal?
I think suggestion #1 should be implemented in v.to.rast anyway,
as it would be a functional improvement for many use cases where
attribute values from vectors are to be transferred to a raster
with DCELL/FCELL type cells.
Your second suggestion would be an alternative, additional
method with its own uses. Easily implemented, I imagine,
by letting the user control the threshold (% of cell area
crossed by line) above which a cell should be set to "1"
(or whatever). In my scenario, a pixel should be placed,
whenever the % crossed area > 0.0.
The value to place could be the line value or an average of
neighbouring cells. Both may have applications.
Best,
Ben
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
