[GRASS-user] newbie question
Hi..
We have a set of lat/lon contour data we converted into ESRI shape file(s). I am using GRASS to verify the data has been converted properly for GIS use by importing/converting the shape file data using v.in.shape. I am then plotting the resultant vector map using d.vect
Although the contours are successfully plotted - the contour labels are not.
I do not see in the documentation how plotting of contour labels is accomplished from a vector map. I thought the vector attributes where automatically handled if properly stored in the original .dbf file.
What am I missing ?
Pete
On Thursday 18 May 2006 13:24, Peter Manousos wrote:
Hi..
not.
What am I missing ?
Pete
Welcome aboard.
vector attributes will not be displayed by default. you can have them shown by
adding the following flags to d.vect:
d.vect contours disp=shape,attr ...
you will need to specify the column name containing your contour labels. check
the d.vect man page for details.
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Yikes.
Is it possible for you to use a newer version of GRASS ? I would recommend
6.1-cvs as it is the most up-to-date.
Dylan
On Thursday 18 May 2006 14:16, Peter Manousos wrote:
Hi Dylan..
Thanks for the quick reply, but I dont see in the man pages on d.vect
allows specification of a column.
I am using GRASS 5.4 and d.vect only allows map=<mapname> color=<color>
and at catnum.
Pete
>> Hi..
>> not.
>> What am I missing ?
>> Pete
> Welcome aboard.
> shown by adding the following flags to d.vect:
> check the d.vect man page for details.
> Cheers,
> Dylan
Dylan Beaudette
530.754.7341
are not.
What am I missing ?
You need to use GRASS 6. Vector attributes in GRASS 5 are very limited.
Import is with v.in.ogr, display with (new) d.vect.
good luck,
Hamish
