Hi. I just started using nviz, and I have been able to sucessfully display raster DEM’s and vector lines (roads). However, I have been trying to add a vector layer of polygons depicting areas of open space, but only the border of the area is projected as a 1px line, the fill remains transparent. In an attempt to correct this, I elevated the vector off the DEM, but with the same result.
Both the vector and raster layers display correctly when viewed in 2D.
Is this an expected outcome, or an error on my part? How do I work around this? Should I convert the vector to raster, with v.to.rast and then add it as an additional layer to show the area fill?
Thanks!
Charlie
raster DEM's and vector lines (roads). However, I have been trying to add
the same result.
To my knowledge a non-feature...
Yes, that would be the fastest solution.
I hope that the new wxNVIZ addresses this problem.
the same result.
In gvd.c, there is:
else {
/* 2D polygons */
/* TODO */
It is possible to convert the 2D areas to 3D and then display in
wxnviz. For example in case of lakes you could assign different z
coordinate to each lake (although I'm not sure how).
However it is not clear to me how the 2D polygon should be rendered in
3D view in a general case.
Please, don't forget that the underlying library is the same for tcltk nviz
Anna
grass-user mailing list
grass-user@lists.osgeo.org
