Hi -
I am trying to open GRASS 8.3 using a grassdata directory located on a personal cloud storage device. GRASS opens using the grassdata last used, and I see no way to navigate to the storage device instead. I tried deactivating the grassdata in my home directory in the hope that it would result in dialogue to navigate to an alternative. But no such luck. I just get a temporary location.
It appears that as late as GRASS 7.9, the first window to open provided the opportunity to select a grassdata located elsewhere - that was not the last used or present in home. Has the new GUI changed this, or am I just missing something obvious?
Any help much appreciated!
Stu
Yes, this has changed, you can add a new directory from the data catalog:
https://youtu.be/OCcM1XfxHW8?feature=shared&t=370
On Wed, May 1, 2024 at 2:45 PM Stuart Edwards via grass-user <grass-user@lists.osgeo.org> wrote:
Hi -
Stu
grass-user mailing list
Thanks for the quick response - that works…
Stu
Hi -
Stu
