[GRASS-user] OSX Yosemite - GRASS 6.4 stopped working
Hi all
I’m running OS X Yosemite Beta, and my GRASS install just stopped working. It was running fine until last week, but now I can’t open it, with the following error msg:
Last login: Mon Sep 1 11:37:04 on ttys002
‘/Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh’; exit
GuanoBookPro:~ guano$ ‘/Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh’; exit
-bash: /Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh: No such file or directory
logout
[Process completed]
The same happens with GRASS-7
I don’t recall updating anything (maybe some automatic update happened in the background), and I already tried to reinstall GRASS.
Trying to run grass.sh from /Applications/GRASS-6.4.app/Contents/MacOS/ will not work as well, first with a Gis_set Error about the splash screen (should a missing splash screen gif cause an error on startup??), and after it, with a python error:
Starting GRASS …
File “./etc/wxpython/gis_set.py”, line 1003, in
GRASSStartUp = StartUp(0)
File “/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py”, line 8631, in init
self._BootstrapApp()
File “/Applications/GRASS-6.4.app/Contents/MacOS/etc/python/wx/_core.py”, line 8196, in _BootstrapApp
return core.PyApp__BootstrapApp(*args, **kwargs)
File “./etc/wxpython/gis_set.py”, line 978, in OnInit
StartUp = GRASSStartup()
File “./etc/wxpython/gis_set.py”, line 95, in init
versionFile = open(os.path.join(globalvar.ETCDIR, “VERSIONNUMBER”))
IOError: [Errno 2] No such file or directory: ‘./etc/VERSIONNUMBER’
Error in GUI startup. If necessary, please
report this error to the GRASS developers.
Switching to text mode now.
Hit RETURN to continue…
So, I went and reinstall wxpython, but again with no success.
any help at this point is very much welcome
best
Carlos
Prof. Carlos Henrique Grohmann
Institute of Energy and Environment - Univ. of São Paulo, Brazil
  • Digital Terrain Analysis | GIS | Remote Sensing -
http://carlosgrohmann.com
http://orcid.org/0000-0001-5073-5572
Can’t stop the signal.
Carlos,
I have seen the same thing; here is what I figured-out as a brute force work-around:
(1) in the TERM window that pops-up do Control-C
(2) copy and paste: /Applications/GRASS-6.4.app/Contents/Resources/Scripts/GRASS.scptContents/MacOS/grass.sh (or the GRASS 7 equivalent)
(3)
This works every time I get this + it seems to temporarily ‘fix’ the problem…
Cheers!
Tom
On Mon, Sep 1, 2014 at 11:00 AM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Hi all
logout
[Process completed]
Starting GRASS …
best
Carlos
grass-user mailing list
grass-user@lists.osgeo.org
Thanks Tom,
but I couldn’t replicate your workaround. You mean the term window that opens when GRASS is started “normally” (from dock or Application)?
If so, mine was a bit fast and I couldn’t hit ctrl-C fast enough to stop it
in a normal term window, just pasting the line you provided also returned me the same error as before (No such file or directory)
best
Carlos
On Mon, Sep 1, 2014 at 1:48 PM, Thomas Adams <tea3rd@gmail.com> wrote:
Carlos,
(3)
Cheers!
Tom
Hi all
logout
[Process completed]
Starting GRASS …
best
Carlos
Carlos,
Yes, the ‘normal’ GRASS TERM window. My apologies; I did not mean to use Control-C during the GRASS launch, but -AFTER- the error appears. What I sent you was from your original post. Interestingly, when I try to launch GRASS on my Mac, I got the error I often see, but your error message is very different from mine.
You get:
The error I get has the path:
/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh
See what happens if you use my path, above. If you have GRASS in your Applications folder, the path I have should work. I have no idea why yours is so different. No wonder GRASS is not launching. BTW, just now, when I used my path above, GRASS just launched just fine for me.
Best,
Tom
On Mon, Sep 1, 2014 at 12:54 PM, Carlos Grohmann <carlos.grohmann@gmail.com> wrote:
Thanks Tom,
best
Carlos
Carlos,
(3)
Cheers!
Tom
Hi all
logout
[Process completed]
Starting GRASS …
best
Carlos
