Hello,
What is the best and fast way to make a copy of a part of vector map (national) to get a smaller territory ? (partial copy).
Thank you for your advice !
Frank
Hello,
Frank
Check v.extract or v.clip
Vero
El mié., 31 oct. 2018 7:20, Frank David <frank.david@geophom.fr> escribió:
Hello,
Thank you for your advice !Frank
grass-user mailing list
grass-user@lists.osgeo.org
The following partial script may be helpful (having the source map in shape format):
import os
import sys
import subprocess
from array import array
import string
import math
from grass.script import core as grass
from grass.script import db as grass
cmd = 'ogr2ogr -clipsrc' + ' ' + v_w + ' ' + v_s + ' ' + v_e + ' ' + v_n
cmd = cmd + ' ' + '~/contours.shp' + ' ~/folder_name/contours.shp'
subprocess.call(cmd, shell = True)
grass.run_command('v.in.ogr', input='contours.shp', layer='contours', output='contours')
Jon
On 31 Oct 2018, at 10:12, Frank David wrote:
Hello,
Hello Vero,
Thanks for your reply. It took almost one hour to extract my area (I guess because of topology). I do the same with Qgis from a shape in less than 10 minutes (but with several operations)… it’s may be a bad idea to have a so heavy vector map in Grass…
Frank
VeroEl mié., 31 oct. 2018 7:20, Frank David <frank.david@geophom.fr> escribió:
Hello,
Hi Jon,
Thanks for your reply. It’s very interesting to make a python script, even if the input data doe not come from grass database as I would like.
Frank
assume folder in home directory containing source map - in this case contours.shp# v_w,v_s,v_e,v_n are string variables with destination region# the commands create a subset defined by the destination region: contours.shp# note that the identical naming of input and output is perhaps confusing but harmless# as long as the home directory does not contain files named contours.*# —# importing required modules
import os
import sys
import subprocess
import string
import math
from grass.script import db as grassexcerpt
cmd = 'ogr2ogr -clipsrc' + ' ' + v_w + ' ' + v_s + ' ' + v_e + ' ' + v_n cmd = cmd + ' ' + '~/contours.shp' + ' ~/folder_name/contours.shp' subprocess.call(cmd, shell = True) grass.run_command('v.in.ogr', input='contours.shp', layer='contours', output='contours')Jon
Hello,
Hei Frank,
Did you try the “spatial” option in v.in.ogr (or the r-flag) (if your data is in a shape-file to start with):
https://grass.osgeo.org/grass74/manuals/v.in.ogr.html ?
And is v.clip slower than v.overlay (that could be used as well)?
Stefan
From: grass-user grass-user-bounces@lists.osgeo.org On Behalf Of Frank David
Sent: onsdag 31. oktober 2018 13:14
To: Veronica Andreo veroandreo@gmail.com
Cc: grass-user grass-user@lists.osgeo.org
Subject: Re: [GRASS-user] partial vector copy to smaller territory
Hello Vero,
Frank
Vero
Hello,
Hi Stefan,
Thank you. I did not know. That’s great.
Frank
Le 31/10/2018 à 13:53, Stefan Blumentrath a écrit :
Hei Frank,
Stefan
Subject: Re: [GRASS-user] partial vector copy to smaller territoryHello Vero,
Frank
Vero
Hello,
Hi Frank,
On Wed, Oct 31, 2018 at 1:39 PM Frank David <frank.david@geophom.fr> wrote:
Hello Vero,
this kind of operation could be much faster in latest GRASS 7.4 than in any previous versions. Which GRASS version are you using?
Markus M
Frank
Hello,
Le 31/10/2018 à 20:57, Markus Metz a écrit :
Hi Frank,
On Wed, Oct 31, 2018 at 1:39 PM Frank David <frank.david@geophom.fr <mailto:frank.david@geophom.fr>> wrote:
> Hello Vero,
> Thanks for your reply. It took almost one hour to extract my area (I guess because of topology). I do the same with Qgis from a shape in less than 10 minutes (but with several operations)... it's may be a bad idea to have a so heavy vector map in Grass...this kind of operation could be much faster in latest GRASS 7.4 than in any previous versions. Which GRASS version are you using?
Hello Markus,
I'm using 7.4.1 on debian9
But my grass db folder is on a small server (Synology NAS), so may be the network makes slow down the operation ?
Frank
Markus M
> Cheers,
> Frank
> Cheers,
> Vero
> El mié., 31 oct. 2018 7:20, Frank David <frank.david@geophom.fr <mailto:frank.david@geophom.fr>> escribió:
>> Hello,
>> Frank
>> _______________________________________________
>> grass-user@lists.osgeo.org <mailto:grass-user@lists.osgeo.org>
Hi Frank,
Hello Vero,
Hello Markus,
I’m using 7.4.1 on debian9
This is possible, but it should not slow it down that much: 10 min vs 1 hour
Can you provide a link to the vector from which you want to extract a small area, and the command you used to extract a small area? Maybe there is scope for optimization.
Markus M
FrankMarkus M
Frank
Hello,
Hi Frank,
Hello Vero,
Hello Markus,
Markus,
The data is CorineLandCover for france. You can download 400mo here > https://we.tl/t-tvldlmkVw3
First I have imported the shape in PERMANENT
and I do : v.extract --verbose input=CLC12_FR_RGF@PERMANENT where=CODE_12 IN (111,112,131,311,312,313,324) output=clc12
Hope it helps you…
Frank
Hi Frank,
Hello Vero,
Hello Markus,
Markus,
Hope it helps you…
import of the shapefile with v.in.ogr takes here 5 minutes
v.extract takes here 27 seconds instead of 1 hour
“here” means a laptop with Intel Core i7 4th generation and standard SATA SSD, i.e. no fancy new high-speed system at all.
I am afraid this does not help you. What could take long is writing attributes, depending on the database connection. I am using the default sqlite database.
You could use top to check if v.extract is running at 100%.
Markus M
FrankMarkus M
FrankMarkus M
Frank
Hello,
Le 02/11/2018 à 22:27, Markus Metz a écrit :
On Fri, Nov 2, 2018 at 6:32 PM Frank David <frank.david@geophom.fr <mailto:frank.david@geophom.fr>> wrote:
> On Fri, Nov 2, 2018 at 11:58 AM Frank David <frank.david@geophom.fr <mailto:frank.david@geophom.fr>> wrote:
> > Hi Frank,
> > > Hello Vero,
> > Hello Markus,
> Markus,
> Hope it helps you...import of the shapefile with v.in.ogr takes here 5 minutes
v.extract takes here 27 seconds instead of 1 hour"here" means a laptop with Intel Core i7 4th generation and standard SATA SSD, i.e. no fancy new high-speed system at all.
Hello Markus,
Thank you for your help.
I'm trying to do again the operation on local machine. I want fisrt, create a vector with only selected data (on full France area). But I've met a problem with v.extract.
v.extract --overwrite --verbose input=CLC12_FR_RGF@PERMANENT type=area where=CODE_12 IN (111,112,121,311,312,313,324) output=CLC12_FR_RGF_BOISBATI@PERMANENT
Loading categories from table <CLC12_FR_RGF>...
DBMI-DBF erreur de pilote :
SQL parser error (syntax error, unexpected NAME processing
'IN') in statement:
SELECT cat FROM CLC12_FR_RGF WHERE CODE_12 IN
Unable to open cursor.
'IN') in statement:
ERROR: Unable select records from table <CLC12_FR_RGF>
It looks that grass does not recognized "IN" sql condition. If I force layer=-1, it runs bur the output vector is the same as input one.
Am I wrong somewhere ? I use Grass 7.4.2 on debian9.
Frank
Markus M
> Cheers,
> Frank
> Markus M
> > Cheers,
> > Frank
> > Markus M
> > > Cheers,
> > > Frank
> > > Cheers,
> > > Vero
> > >> Hello,
> > >> Frank
Hi Frank,
Hello Vero,
Hello Markus,
Markus,
Hope it helps you…
v.extract takes here 27 seconds instead of 1 hour“here” means a laptop with Intel Core i7 4th generation and standard SATA SSD, i.e. no fancy new high-speed system at all.
Hello Markus,
I’m trying to do again the operation on local machine. I want fisrt, create a vector with only selected data (on full France area). But I’ve met a problem with v.extract.
Loading categories from table <CLC12_FR_RGF>…
‘IN’) in statement:
‘IN’) in statement:
It looks that grass does not recognized “IN” sql condition. If I force layer=-1, it runs bur the output vector is the same as input one.
DBF does not recognize the “IN”. It is highly recommended to leave the GRASS database connection at the default sqlite. You can reset the GRASS database connection to the default with
db.connect -d
After that verify with
db.connect -p
Markus M
Frank
Markus M
FrankMarkus M
FrankMarkus M
Frank
Hello,
DBMI-DBF
--> the use of the DBF driver is the reason why it is so slow at your end.
As soon as you switch to the SQLite backend (see Markus Metz'
suggestion from today), it will be much faster.
Just for clarification,
markusN
> > Hi Frank,
> > > Hello Vero,
> > Hello Markus,
> Markus,
Hello Markus,
'IN') in statement:
'IN') in statement:
ERROR: Unable select records from table <CLC12_FR_RGF>It looks that grass does not recognized "IN" sql condition. If I force layer=-1, it runs bur the output vector is the same as input one.
Frank
I've repeated the operation v.in.ogr and v.extract with success on different grass mapset, but I get always the same error (on v.extract : see above) only with one of my local grass mapset (PERMANENT). I do not understand what happens...
Frank
mailto:[frank.david@geophom.fr](mailto:frank.david@geophom.fr)> wrote:Le 02/11/2018 à 14:43, Markus Metz a écrit :
mailto:[frank.david@geophom.fr](mailto:frank.david@geophom.fr)> wrote:Le 31/10/2018 à 20:57, Markus Metz a écrit :
Hi Frank,
<frank.david@geophom.fr mailto:[frank.david@geophom.fr](mailto:frank.david@geophom.fr)> wrote:Hello Vero,
may be a bad idea to have a so heavy vector map in Grass…this kind of operation could be much faster in latest GRASS 7.4
than in any previous versions. Which GRASS version are you using?Hello Markus,
may be the network makes slow down the operation ?This is possible, but it should not slow it down that much: 10 min
vs 1 hourCan you provide a link to the vector from which you want to extract
there is scope for optimization.Markus,
https://we.tl/t-tvldlmkVw3First I have imported the shape in PERMANENT
where=CODE_12 IN (111,112,131,311,312,313,324) output=clc12Hope it helps you…
SATA SSD, i.e. no fancy new high-speed system at all.I am afraid this does not help you. What could take long is writing
default sqlite database.You could use top to check if v.extract is running at 100%.
Hello Markus,
I’ve met a problem with v.extract.v.extract --overwrite --verbose input=CLC12_FR_RGF@PERMANENT type=area
‘IN’) in statement:
‘IN’) in statement:
ERROR: Unable select records from table <CLC12_FR_RGF>It looks that grass does not recognized “IN” sql condition. If I force
layer=-1, it runs bur the output vector is the same as input one.Am I wrong somewhere ? I use Grass 7.4.2 on debian9.
Frank
I’ve repeated the operation v.in.ogr and v.extract with success on
understand what happens…
In the current mapset, the default database connection must not be DBF. You can reset the default database connection to sqlite with
db.connect -d
db.connect -p
that sqlite is indeed the default database connection.
Now you can repeat with v.in.ogr + v.extract
Markus M
Hi Frank,
Hello Markus,
‘IN’) in statement:
‘IN’) in statement:
Frank
understand what happens…In the current mapset, the default database connection must not be DBF. You can reset the default database connection to sqlite with
db.connect -d
db.connect -p
that sqlite is indeed the default database connection.Now you can repeat with v.in.ogr + v.extract
Markus M
I’m afraid it’s not the problem…
db.connect -d
Pilote par défaut / base de données définie à :
pilote : sqlite
base : /media/hdd1/grassdata/France_L93/PERMANENT/sqlite/sqlite.db
(Wed Nov 7 10:46:01 2018) La commande s’est terminée (0 sec)
(Wed Nov 7 10:46:29 2018)
db.connect -p
driver: sqlite
database: /media/hdd1/grassdata/France_L93/PERMANENT/sqlite/sqlite.db
schema:
group:
and when execute v.extract I get the same error…
I have tested again the same operation in other mapset than PERMANENT, and it works. I don’t understand… if any idea ?..
Frank
Hi Frank,
Hello Markus,
‘IN’) in statement:
‘IN’) in statement:
Frank
db.connect -d
db.connect -p
Markus M
db.connect -d
pilote : sqlite
db.connect -p
driver: sqlite
schema:
group:and when execute v.extract I get the same error…
Have you re-imported the vector?
What is the output of v.db.connect map=CLC12_FR_RGF -p
The “IN” SQL syntax works only if the vector CLC12_FR_RGF is not using dbf. You must make sure with “v.db.connect map=CLC12_FR_RGF -p” that CLC12_FR_RGF is really using sqlite as database driver.
HTH,
Markus M
Frank
