[GRASS-user] PBS
HI all!
Albert Saribekyan.
I do make and install in GRASS7 i.vi.mpi module, its already running all right !!
I have wrote and run my script outside of GRASS and its also worked ok! script is in attached file!!
but I have to write a PBS script for that
something like this #!/bin/bash
#PBS -N ndvi_mpi
#PBS -e ndvi_mpi.err
#PBS -o ndvi_mpi.log
#PBS -q armgrid
#PBS -l nodes=1:ppn=4
echo Master process running on `hostname`
echo Directory is `pwd`
echo PBS has allocated the following nodes:
echo `cat $PBS_NBODEFILE`
# Define number of processors to send to mpirun for MPICH
NPROCS=`wc -l < $PBS_NODEFILE`
echo This job has allocated $NPROCS nodes
/bin/hostname
but do not know what to write next...
tell me something;
regards Albert.
(attachments)
i.vi.mpi.txt (834 Bytes)
Albert Saribekyan.
---------- Пересланное сообщение ----------
От кого: Albert Saribekyan (albertsaribekyan@rambler.ru)
Дата: 5 Октябрь 2012 г. 18:46:23
Тема: PBS
Кому: (grass-user@lists.osgeo.org)
PBS
HI all!
Albert Saribekyan.
#PBS -N ndvi_mpi
#PBS -q armgrid
/bin/hostname
tell me something;
regards Albert.
(attachments)
On Fri, Oct 5, 2012 at 4:46 PM, Albert Saribekyan
<albertsaribekyan@rambler.ru> wrote:
HI all!
Albert Saribekyan.
right !!
#PBS -N ndvi_mpi
#PBS -q armgrid
/bin/hostname
tell me something;
You may want to check:
http://grass.osgeo.org/wiki/Parallel_GRASS_jobs#Cluster_and_Grid_computing
Years ago I worked with PBS, then switched to Grid Engine.
Both work very similar.
