[GRASS-user] point map from centroids of polygons
hello
how can I create a vector point map from centroids of polygons ?
regards
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
On Thu, November 1, 2007 15:24, temiz wrote:
hello
v.type type=centroid,point ?
Moritz
hello
Moritz
thank you
may be I couln't expain the problem well.
I need to have centroid points of polygons and create a new point map from them.
v.type still gives a boundary map
regards
I think v.type is ok. You should use input and outpu arguments:
v.type input=map_with_polygons output=map_with_points type=centroid,point
Giovanni
2007/11/1, temiz <temiz@deprem.gov.tr>:
>> hello
> Moritz
thank you
from them.
regards
grassuser mailing list
grassuser@grass.itc.it
Have you considered using v.extract to extract points from
v.type's output? Or v.edit to delete boundaries?
