i'm trying to use the v.out.postgis module and exported a grass vector
into postgis,
also, using the output_link option i linked the layer to GRASS,
althought i can display the geometry i cannot open the attribute table
in GRASS of the linked layer...
can it be a memory issue? the layer have almost 40,000 elements
I also noticed that using v.out.postgis to export to postgis simple
feature format (no -l flag)
i can browse data in postgis but i only found 3 columns: "fid" "cat"
"geom" is this the expected behaviour?
thanks, Roy
