[GRASS-user] POW() in SQLite?
I am trying to use POW(x,n) with SQLite but it fails:
G65> v.db.select mapname column="POW(length,3)"
DBMI-SQLite driver error:
Error in sqlite3_prepare():SELECT POW(length,3) FROM mapname
no such function: POW
ERROR: Unable to open select cursor
Similar problem if I try x^n:
unrecognized token: "^"
What I really want to do is add that value as a new column:
G65> v.db.update mapname column=volume value="POW(length,3)" --verbose
but I get the same error. It doesn't work with DBF either, but I sort
of expected that.
this random webhit suggests that it should be possible:
  http://osdir.com/ml/sqlite-users/2009-03/msg00248.html
any ideas?
not a DB guru,
Hamish
Hamish,
   Mathematical functions such as POW() are not part of SQL. When you look at
what appear to be mathematical functions, e.g., ABS(). MIN(), MAX(), they
are actually string manipulations.
   SQLite stores most values as text strings so this is not surprising.
   I'd manipulate those values first, then pass them to SQLite.
Rich
Nope; not in SQLite:
  http://www.sqlite.org/lang_corefunc.html
SQLite doesn't have a power operator:
  http://www.sqlite.org/lang_expr.html#binaryops
That says:
* Mathematical SQL Functions - The following mathematical SQL functions are
available in addition to the SQLite default: ACOS(), ASIN(), ATAN(), ATAN(),
ATAN2(), CEIL(), CEILING(), COS(), COT(), DEGREES(), EXP(), FLOOR(), LN(),
LOG(), LOG(), LOG2(), LOG10(), MOD(), PI(), POW(), RADIANS(), SIGN(), SIN(),
SQRT(), TAN(), TRUNCATE().
Note: "in addition to the SQLite default". IOW, those functions are
added by SQLiteSpy, and are not part of SQLite.
Glynn:
That says:
functions are added by SQLiteSpy, and are not part of SQLite.
ah, skimming error.
Rich:
solution:
#no good:
#v.db.update basemap column=volume value="POW(length,3)" --verbose
#good:
v.db.select basemap column=cat,length | awk -F'|' \
  '{printf("UPDATE basemap SET volume=%f WHERE cat=%d;\n", $2^3, $1)}' \
  | db.execute
thanks,
Hamish
