[GRASS-user] problem importing data from GNS
the GNS format was changed. GRASS' v.in.gns was fixed for this in 6.2.2:
http://grass.itc.it/announces/announce_grass622.html
Please update (preferably to 6.2.3).
mohannbr wrote:
    i use grass6.2.1 in fedora core 6.while trying to import data from GNS
using the command ..
   v.in.gns file=indata/uk/uk.txt vect=cities
        i got the following warnings and error...
WARNING: Unparsable LatLong value found: LAT
WARNING: Unparsable LatLong value found: LONG
Maximum input row length: 283
Maximum number of columns: 26
Minimum number of columns: 26
ERROR: x column is not of number type
..the command is supposed to create an input map cities which would be
further required to process the data.Since i'm not able to get this input
map done, i can't proceed with the processing part.please help in finding
a soln..
View this message in context: http://www.nabble.com/problem-importing-data-from-GNS-tp14364049p14364216.html
