Hello again,
as recommended I removed the python.org-python (and removed the lines to python.framework in the PATH.
When I now start python it is only the version 2.6.1 (also GRASS now uses this version) which should be the system-python. After removing the other python I recompiled the most recent version of GRASS 6.5, put my mapcalc-testscript into the bin folder and tried to run it both, from launch script and from the GRASS-Terminal. But there is still the same error:
GRASS 6.5.svn (gisdemo_ncspm):~ > testscript.py newmap=test elevation=elevation geology=geology
File "/Library/GRASS/6.5/Modules/bin/testscript.py", line 54, in <module>
sys.exit(main())
File "/Library/GRASS/6.5/Modules/bin/testscript.py", line 47, in main
grass.mapcalc("${newmap} = ${elevation} * ${geology}",
AttributeError: 'module' object has no attribute 'mapcalc'
Here some addtional info from within the GRASS Terminal:
echo "$PYTHONPATH"
/Applications/GRASS-6.5.app/Contents/MacOS/etc/python
my sys.path (in GRASS-terminal python) is:
['', '/Library/Frameworks/SQLite3.framework/Versions/3/Python', '/Library/Python/2.6/site-packages/numpy-override', '/Library/Frameworks/GDAL.framework/Versions/1.8/Python/site-packages', '/Library/Frameworks/cairo.framework/Versions/1/Python', '/Applications/GRASS-6.5.app/Contents/MacOS/etc/python', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6/site-packages/wx-2.8-mac-unicode', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python26.zip', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-darwin', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/plat-mac/lib-scriptpackages', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-tk', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-old', '/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/lib-dynload', '/Library/Python/2.6/site-packages', '/usr/local/lib/wxPython-unicode-2.8.11.0/lib/python2.6', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/PyObjC', '/System/Library/Frameworks/Python.framework/Versions/2.6/Extras/lib/python/wx-2.8-mac-unicode']
that is strange because there is no python.framework anymore so where does this come from?
The normal Terminal gives me for $PATH:
/opt/local/bin:/opt/local/sbin:/usr/bin:/bin:/usr/sbin:/sbin:/usr/local/bin:/usr/X11/bin
So maybe the sys.path is a hint for my problem...
/johannes
-------- Original-Nachricht --------
Datum: Sun, 3 Apr 2011 15:27:41 -0700
Von: Michael Barton <Michael.Barton@asu.edu>
An: Johannes Radinger <JRadinger@gmx.at>
CC: "grass-user@lists.osgeo.org" <grass-user@lists.osgeo.org>
Betreff: Re: [GRASS-user] Problem with Python Scripts and grass.script (GRASS 6.5SVN) on Mac
When I and others have had a copy of Python from
python.org<http://python.org> installed, it has usually caused problems, including bogus errors. I
strongly advise against it. In theory, it should not be a problem, but in
reality (in my experience) it IS a problem.
I can't say for sure that this is where your problem lies, but I'd be
suspicious. When you start python from the terminal, which one is it? How about
from GRASS?
Michael
____________________
C. Michael Barton
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Apr 3, 2011, at 12:23 PM, Johannes Radinger wrote:
Hello Glynn,
Hello Michael,
the answers to your suggestions/questions below:
Am 02.04.2011 um 17:24 schrieb Michael Barton:
Have you installed Python from python.org<http://python.org/> on your Mac?
If you have, there may be a problem with that.
Yes I there is python2.6.6 from python.org<http://python.org/> installed
but William Kyngesburye told me that this shouldn't be any
Problem and GRASS GIS can handle this, but I am not sure. Maybe I've to
try to deinstall it, but I don't know how excatly so that everything is
removed correctly also in the libs.
Michael
C. Michael Barton
http://csdc.asu.edu/>
Am 03.04.2011 um 00:37 schrieb Glynn Clements:
I tried to figure out the problem with william kyngesburye.
the script is also working on his mac. I saved the script in the bin
folder and ran in the GRASS terminal:
What causes this AttributeError?
The grass.script module is either broken or very old (the mapcalc()
The GRASS build I've got is compiled from last weeks source (6.5)...
function was added in December 2008).
>From within GRASS, try the following:
$ python
> import grass.script as grass
> print grass.__file__
that is what I get... does that help you?
/Applications/GRASS-6.5.app/Contents/MacOS/etc/python/grass/script/__init__.pyc
> print grass.__path__
and for the path:
['/Applications/GRASS-6.5.app/Contents/MacOS/etc/python/grass/script']
/johannes
Glynn Clements <glynn@gclements.plus.com<mailto:glynn@gclements.plus.com>>
grass-user mailing list
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
