when i use r.proj to reproject it from lat-long location to albers equal area projection. it is not reponding. After one hour the output is same on screen.
#i entered the following command:
r.proj input=ras_1 location=ll_rast mapset=root dbase=/root/GRASSDATA output=ra_map2 method=nearest
#when executed i receive message on screen as :
Input Projection Parameters: +proj=longlat +a=6377301.243 +rf=300.8017 +no_defs
Input Unit Factor: 1
Output Projection Parameters: +proj=aea +lat_0=0.0000000000 +lat_1=13.0000000000 +lat_2=43.0000000000 +lon_0=82.0000000000 +x_0=0.0000000000 +y_0=0.0000000000 +a=6377301.243 +rf=300.8017 +no_defs
Output Unit Factor: 1
#output of my g.region of albers equal area is as follows:
projection: 99 (Albers Equal Area)
zone: 0
datum: WGS84
ellipsoid: evrst56
north: 4319524.94
south: 838278.56
west: -1700818.5
east: 1371967.17
nsres: 0.1
ewres: 0.1
rows: 34812464
cols: 30727857
cells: 1069712415609648
WOW! With such small resolution in your Alberts location, no wonder
r.proj is having a hard time. Try to set the resolution in the output
location to something more reasonable and compatible with you original
map resolution...
Daniel
On Thu, Jan 29, 2009 at 11:16 AM, Mohammed Rashad <rashadkm@gmail.com> wrote:
screen.
+no_defs
zone: 0
datum: WGS84
ellipsoid: evrst56
north: 4319524.94
south: 838278.56
west: -1700818.5
east: 1371967.17
nsres: 0.1
ewres: 0.1
rows: 34812464
cols: 30727857
grass-user mailing list
grass-user@lists.osgeo.org
