[GRASS-user] Problem with TRMM data and r.in.bin
Hello list,
I’m trying to import the 3b42rt TRMM product by using r.in.bin.
I’ve used the follow lines,
r.inr.in.bin --o -f -h input=2001-1-1.bin output=2001-1-1 north=-16 south=-57 east=50 west=76 cols=104 rows=197
but, always i got the follow error message:
ADVERTENCIA: File Size 519968 … Total Bytes 81952
if i don’t use the -h flag, then the error is:
ERROR: Invalid north latitud.
Now i´ḿ guessing my python script to download a .bin file with a subset area is working bad,
this is the script,
from urllib2 import *
from urllib import urlopen
import os
import datetime
init=2001 #start year to download
final=2002 #end year
month_in=1
month_end=5
day_in=1
day_end=31
north="-16" #subset corners
south="-57"
east="-50"
west="-76"
ldirectory="/media/TOSHIBA/trmm_historica/" #destination folder
#Function to conect and download trmm data
def download(url, file_name):
	try:
		ur = urlopen(url)
		contents = ur.readlines()
		fo = open(file_name, "w")
		print "conected..."
		for line in contents:
	        	fo.write(line)
    		fo.close()
	except  Exception, e:
		print "not possible to conect"
		print str(e)
		sys.exit(2)
for year in range(init,final):
	for month in range(month_in,month_end):
		for day in range(day_in,day_end):
			url = "[http://disc2.nascom.nasa.gov/daac-bin/Giovanni/tovas/Giovanni_cgi.pl?west=](http://disc2.nascom.nasa.gov/daac-bin/Giovanni/tovas/Giovanni_cgi.pl?west=)"+west+"&north="+north+"&east="+east+"&south="+south+"&params=0%7C3B42RT&plot_type=Area+Plot&byr="+str(year)+"&bmo="+str(month)+"&bdy="+str(day)+"&eyr="+str(year)+"&emo="+str(month)+"&edy="+str(day)+"&begin_date=2000%2F03%2F01&end_date="+str(year)+"%2F"+str(month)+"%2F"+str(day)+"&cbar=cdyn&cmin=&cmax=&yaxis=ydyn&ymin=&ymax=&yint=&ascres=0.25x0.25&global_cfg=[tovas.global.cfg.pl](http://tovas.global.cfg.pl)&instance_id=realtime&prod_id=3B42RT_daily&action=ASCII+Output"
			print str(year)+"-"+str(month)+"-"+str(day)
			download(url, ldirectory+str(year)+"-"+str(month)+"-"+str(day)+".bin")
thanks in advance if somebody can see something that i can´t do it and solve my problem.
if somebody could help me, i´ĺl really appreciate it
Diana Marcela Brito Hoyos
Bióloga
"El bosque sería muy triste si solo cantaran los pájaros que mejor lo hacen"
Diana Brito wrote:
I'm trying to import the 3b42rt TRMM product by using r.in.bin.
I've used the follow lines,
ADVERTENCIA: File Size 519968 ... Total Bytes 81952
r.in.bin reads raw binary input. E.g. the above command expects the
file to contain 197*104*4 = 81952 bytes (197 rows by 104 columns by 4
bytes per value).
According to this:
http://www.eol.ucar.edu/projects/name/documentation/3B42RT_README
The original 3B42RT data consists of a 2880-byte header followed by 3
arrays of 480 rows by 1440 columns, the first two being 2 bytes per
value (for a total of 480*1440*2 = 1382400 bytes each) and the third
being 1 byte per value (for a total of 480*1440 = 691200 bytes).
But given the URL you're using:
url = "....prod_id=3B42RT_daily&action=ASCII+Output"
I wouldn't be surprised if the data is being converted to ASCII, in
which case r.in.bin would be entirely the wrong tool to import it.
Thanks for your answer Glynn,
You are totally right, Now i know my script is downloading an ascii file instead a binary file, thats the reason why r.in.bin doesn´t work,
i´m sorry, I didn’t realize about that before.
thanks!!!
2015-05-08 0:45 GMT-03:00 Glynn Clements <glynn@gclements.plus.com>:
file to contain 1971044 = 81952 bytes (197 rows by 104 columns by 4
bytes per value).
According to this:
value (for a total of 48014402 = 1382400 bytes each) and the third
But given the URL you’re using:
url = “…prod_id=3B42RT_daily&action=ASCII+Output”
I wouldn’t be surprised if the data is being converted to ASCII, in
Bióloga
