when using v.rast.stats to get stats for a raster over a polygon layer, I get the following error:
DBMI-DBF driver error:
Error while executing: 'ALTER TABLE caop09c2 ADD COLUMN a2_per0-10 DOUBLE PRECISION
Cannot continue (problem adding column).
SQL parser error: syntax error, unexpected '-' processing '-'
in statement:
Error in db_execute_immediate()
Cannot continue (problem adding columns).
This only happens when I choose the extended statistics option. If not, it works fine. Actually, GRASS
adds all the new fields but does not calculate the quantiles.
An extra question: is it possible to get more quantiles than those calculated using the default (1st,
median and 3rd)?
António
Could you please copy-paste the exact command you have used?
in statement:
Antonio, maybe it's the "-" character (in the table's name) that gets on
the way. But as far as I remember, it should be ok to use it [1].
Nikos
median and 3rd)?
[1] http://grass.osgeo.org/gdp/html_grass64/sql.html
Please ignore this question...
On Apr 5, 2010, at 9:34 PM, António M. Rodrigues wrote:
in statement:
median and 3rd)?
António
grass-user mailing list
grass-user@lists.osgeo.org
