Hi all.
I have a problem with v-edit.
I have to break a vector line
into two parts near a point. I gave this command:
v.edit map=ret_125
layer=1 type=line tool=break thresh=$ris_edit coords=$x,$y snap=no
where " $ris_edit " depends on the resolution of the DEM raster map,
"$x" and "$y" are the coordinates of the point.
I'm using GRASS 6.3.
What I'm missing?
_______________________________________________________
Stampa le tue foto a 0,09 €. Non farti sfuggire questa offerta
http://photo.tiscali.it/offerte/promo-natale.shtml
2009/1/20 chiaraercoli@tiscali.it <chiaraercoli@tiscali.it>:
v.edit map=ret_125
are you sure that threshold value is enough to select vector feature
which you want to break?
v.edit map=ret_125 tool=select thresh=$ris_edit coords=$x,$y
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
