[GRASS-user] ps.map and line style
Hello,
in a map composition I need to draw contours with two particular
linestyles:
- a line bedecked with crosses: ----x----x----x----x----
- a double line: =====================
I am wondering if there is a simple way to specify e.g. a postscript
linear pattern that applies to vlines, the same way we can with vareas.
Any idea ?
Vincent
Vincent Bain wrote:
Hello,
linestyles:
Hi Vincent,
I have plotted a double line like this:
vlines my_lines
    color yellow
    width 1.5
    label Chirp lines
    lpos 4
    style 000111
end
vlines my_lines
    color black
    width 3
    label Chirp lines
    lpos 4
    style 000111
end
The top entry in the file plots on top in the map. This gives a black dotted line with a yellow middle. Specifying the same legend position recreates the pattern in the legend.
Later
John
Dr John Stevenson
Postdoctoral Research Associate
School of Earth, Atmospheric and Environmental Sciences
Williamson Building (Room 2.42)
University of Manchester
Manchester M13 9PL, UK
tel. +44(0)161 306 6585; fax. +44(0)161 306 9361;
john.stevenson@manchester.ac.uk
particular
linestyles:
I suspect for that you might have to use the v.lrs modules or
v.to.points to make points along the line at a regular interval,
then display them over the top with a vpoints command. Perhaps
there is another way though.
Hamish
Hi John,
thanks for the trick, I'll give it a try, though I need two black lines
with /transparency/ in between.
Vincent.
Le mardi 12 janvier 2010 à 10:10 +0000, John A Stevenson a écrit :
Vincent Bain wrote:
> Hello,
> linestyles:
Hi Vincent,
vlines my_lines
    color yellow
    width 1.5
    label Chirp lines
    lpos 4
    style 000111
end
vlines my_lines
    color black
    width 3
    label Chirp lines
    lpos 4
    style 000111
end
Later
John
Yes Hamish, this is what I was planning to do in the end.
If I go this way, I'll probably have to implement an 'angle' attribute
in order to align my point symbols on the line direction... Will give it
a try too,
thank you,
Vincent.
Le mardi 12 janvier 2010 à 02:57 -0800, Hamish a écrit :
> particular
> linestyles:
Hamish
Vincent:
I need two black lines with /transparency/ in between.
try the offset or coffset setting within the vlines instruction:
       offset (experimental) - offset for the vectors lines in pixels for plotting parallel
       lines in distance equal to offset (accepts positive or negative decimal points).
       Useful to print streets with several parallel lanes;
       coffset (experimental) - offset for the vectors lines. If coffset is used then off-
       set of line is equal to coffset * category value and offset is used in legend;
(I think that "pixels" should really say "points", but..)
Hamish
