Hello,
I have been toying with creating 3D surfaces from my vector data (contour lines) matched to my AirPhotos out of interest.
My vector file has a category “ELEVATION” with all the z values in meters.
Now, when I try to run v.surf.rst I receive this output:
DBMI-Postgres driver error:
Cannot select:
SELECT cat, ELEVATION FROM w0124.contour
ERROR: column “cat” does not exist
LINE 1: SELECT cat, ELEVATION FROM w0124.contour
Reading lines from vector map …
Database record for cat 1 not found
It is true I do not have this column “cat” in my w0124.contour table.
I am interested in understanding what this column “cat” is used for and some more information on how I should be addressing this issue.
Thank you.
Mars
Amaginary Studios
amagine@telus.net
Phone 250 845 7999
Mars Sjoden
3320 Mount Davis Way
Houston BC
V0J 1Z2
READ CAREFULLY.
By reading this email, you agree, on behalf of your employer, to release me from all obligations and waivers arising from any and all NON-NEGOTIATED agreements, licenses, terms-of-service, shrinkwrap, clickwrap, browsewrap, confidentiality, non-disclosure, non-compete and acceptable use policies (“BOGUS AGREEMENTS”) that I have entered into with your employer, its partners, licensors, agents and assigns, in perpetuity, without prejudice to my ongoing rights and privileges. You further represent that you have the authority to release me from any BOGUS AGREEMENTS on behalf of your employer.
On 18-Mar-07, at 11:09 AM, Paolo Cavallini wrote:
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
BTW: I was able to start something with: python gism.py
Not really functional, though.
pc
Some spare time finally allows me to test the new python gui. I compiled
- -with-python fom CVS, and tried starting with grass63 -wxpython, but
this is not recognized.
I have python-wxversion, python-glade2 and python-gtk2 installed in my
system. Should I also have something else?
Yes, you need the actual GUI code, which isn’t in CVS but in a
separate subversion repository:
svn co https://grasssvn.itc.it/svn/grassaddons/trunk/grassaddons/gui
It isn’t ready for use yet.
Paolo Cavallini
email+jabber: cavallini@faunalia.it
www.faunalia.it
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFF/YBr/NedwLUzIr4RAlrNAJ9ENBbzly2JfrbLLk4apohhdND7AACeK7G5
n2J94taTwOKvLNElWrgVmbQ=
=JGo2
-----END PGP SIGNATURE-----
grassuser mailing list
grassuser@grass.itc.it
