Sto usando il pc di un collega, che ha installato Qgis per Windows. Ci sono dei problemi con l’r.out.gdal lanciato dalla shell msys.
Viene chiesto come parametro type di uscita o Byte o UInt16 (Float32 mi restituisce errore) e il tif generato è illeggibile in altri gis, eccetto Qgis stesso.
Ne sapete qualcosa?
sono
dei problemi con l'r.out.gdal lanciato dalla shell msys.
Qgis stesso.
Ne sapete qualcosa?
Giova
Hai scritto alla lista in italiano
Which QGIS version do you use? That's essential to know.
Which error do you get with Float32?
Note that I have fixed GeoTIFF color tables in r.out.gdal in
6.3.0RCx (which will hopefully reach QGIS 0.9.1 for Windows/Mac).
Hi Markus,
the pc I was using has Qgis 0.9.0.26 for Windows.
The raised error is
"ERROR 6: SetColorTable only supported for Byte or UInt16 bads in Tiff format".
I get the same with r.out.gdal from Grass on my Ubuntu.
If I try with r.out.tiff it alerts me that decimal values will be
rounded to integer values, but the otuput seams correct...
Giovanni
> sono
> Qgis stesso.
> Ne sapete qualcosa?
> Giova
Hi Markus,
The raised error is
You can use the "old", shell script version of r.out.gdal,
in 6.3 available as r.out.gdal.sh. It is slower but
reliable. Most importantly IMHO it's free from the bug
present in the C r.out.gdal version, that it sets NoData
wrong, corrupting the output raster [1].
Hi Markus,
The raised error is
format".
I didn't think it was such a hard task to export a geotiff...
I've tried with the aspect from spearfish, trying to keep the decimal
values (FCELL), but nothing to do...
I'll wait for Grass 6.3 to be packaged.
2007/12/1, Markus Neteler <nseteler@fbk.eu>:
G. Allegri wrote:
> Hi Markus,
> The raised error is
> format".
G. Allegri wrote:
> The resulting tiff appears uncorrect, with lot of blank areas...
> This is what I get in coth cases:
> http://www.geospatial.it/allegri/img/aspect_out.JPG
"Just" get a fresh GRASS 6.3 version (or the upcoming QGIS 0.9.1).
