[GRASS-user] query by distance
Hi All,
there is an easy way to select (on a raster map) all features into a certain radius from a specific point?
Thanks
Bye
Edmondo
On Thu, 2008-10-09 at 15:24 +0200, Edmondo Elisei wrote:
Hi All,
Thanks
Bye
Edmondo
Maybe something using r.buffer/v.buffer --> YourBuffer (rasterize if it
comes from v.buffer), then r.mapcalc MASK=YourBuffer, then operate
within the MASK?
Regards, Nikos
Edmondo:
Nikos:
within the MASK?
fyi I've recently added a new addon module called r.what.vect.buffer.
  http://grass.osgeo.org/wiki/GRASS_AddOns#v.what.rast.buffer
The idea is to provide local environmental context to a series of vector
points.
v.what.rast or r.what + coord alone may return a spike in the raster data
without you knowing. What this script does is create a buffer around each
vector point and gather some stats about the raster cells nearby and
report them in a .csv table. Multiple raster maps can be sampled.
I assume the location is not lat/lon, and (in column names) that units
will be meters. (r.buffer would be lat/lon safe; but I used r.circle
because it allows starting from an exact coord not from the nearest cell)
v.rast.stats + v.buffer is problematic when input points' buffers overlap.
GRASS> v.what.rast.buffer --help
Description:
Calculates univariate statistics of raster map(s) from buffers around vector points.
Results are written to a file. Resolution is taken from each input map.
Keywords:
vector, raster, statistics
Usage:
v.what.rast.buffer input=name raster=name[,name,...] buffer=value
   [output=name] [fs=character] [--verbose] [--quiet]
Flags:
--v Verbose module output
--q Quiet module output
Parameters:
   input Points vector map containing query positions
  raster Name of raster map(s) to calculate statistics from
  buffer Buffer distance in map units
           default: 100
  output Name for output file (if omitted or "-" output to stdout)
      fs Field separator in output file
           default: |
spearfish example:
  v.what.rast.buffer in=archsites rast=elevation.dem,slope out="-"
enjoy,
Hamish
On Thursday 09 October 2008, Hamish wrote:
Edmondo:
Nikos:
> within the MASK?
points.
Description:
vector points. Results are written to a file. Resolution is taken from each
input map.
Keywords:
Usage:
Flags:
Parameters:
           default: 100
           default: |
spearfish example:
enjoy,
Hamish
Interesting! This functionality is also StarSpan, albeit not within a
raster-only context. It would be interesting to compare the results!
Dylan
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
