I am using GRASS 7.8 and now need to conduct an analysis using* r.cva*. But
the problem is that the addon module is prepared for GRASS 6.0 and I have to
compile and install it. The g.extension seems not work very well with this
module.
I have downloaded the tar.gz file and googled many method to compile it but
I still failed.. Could you give me some clues or give me some suggestions
about next steps?
module.
There is also the GRASS GIS 7 version (see above).
about next steps?
You can give the module name as a parameter to g.extension:
