[GRASS-user] Question concerning r.to.vect and out of memory error
Hi
my system: SuSE 10.2, Dual core processor, 1GP physical memory, 16GB swap (one swap partition of 1GB and one swap file of 15GB)
I have a huge DEM from which I calculated the slopes and categorised them in 10% classes. Now I want to use r.to.vect to convert them into a vector layer of type area. My problem is that I get an out of memory error, even though there is enough memory available. It seems that GRASS 6.2.1 only uses the swap partition and not the swap file (which would be really strange).
by using "free -m" , I got the following memory information (in megabytes) when r.to.vect quit with an out of memory error:
              total used free shared buffers cached
Mem: 1011 998 12 0 1 103
-/+ buffers/cache: 894 117
Swap: 17299 1043 16255
Any ideas on how I can avoid this?
By the way: before I started grass, I created the swapfile with
dd ...
mkswap ...
swapon ...
Any help welcome,
Rainer
NEW EMAIL ADDRESS AND ADDRESS:
Rainer.Krug@uct.ac.za
RKrug@sun.ac.za WILL BE DISCONTINUED END OF MARCH
Rainer M. Krug, Dipl. Phys. (Germany), MSc Conservation
Biology (UCT)
Leslie Hill Institute for Plant Conservation
University of Cape Town
Rondebosch 7701
South Africa
Fax: +27 - (0)86 516 2782
Fax: +27 - (0)21 650 2440 (w)
Cell: +27 - (0)83 9479 042
Skype: RMkrug
email: Rainer.Krug@uct.ac.za
         Rainer@krugs.de
One additional information: huge means:
Rows: 25960
Columns: 23211
     Total Cells: 602557560
Rainer
Rainer M. Krug wrote:
Hi
dd ...
mkswap ...
swapon ...
Any help welcome,
Rainer
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
> cached
> 103
> dd ...
> mkswap ...
> swapon ...
Rows: 25960
Columns: 23211
does the map contain integers or floats?
(CELL map, FCELL map, or DCELL? [from r.info])
Even with 16GB ram, Linux can only allocate so much per process.
see http://kerneltrap.org/node/2450
Was GRASS built by hand with large file support?
Was your linux kernel built with CONFIG_HIGHMEM or similar?
32 or 64bit machine? 64bit linux kernel?
Hamish
32 or 64-bit CPU/OS?
really strange).
If you're on a 32-bit system, you may be running into the upper limit
on the amount of memory which can be used by a single process. The
exact figure can vary between systems, but anything over 2GB is
pushing it. Adding more swap (or RAM) won't help if the issue is with
a single process.
dd ...
mkswap ...
swapon ...
Rows: 25960
Columns: 23211
Data Type: CELL
No - I installed it from the rpm for SuSE 10.2
I don't think so - I use the standard kernel from SuSE 10.2
(2.6.18.8-0.1 on the one machine - as all updates are done on both
machines, I think that the second one has the same kernel.)
32 bit machine
As I think that the problem is not that easy to solve (according to your
  - thanks for the link - and Glynns info) without recompiling the
kernel - I will have to go the other route to solve the problem and to
split the raster into smaller ones. As this is a different topic, please
see my other email.
Thanks you to for your help,
Rainer
Hamish
grassuser mailing list
grassuser@grass.itc.it
Biology (UCT)
Rondebosch 7701
South Africa
Skype: RMkrug
         Rainer@krugs.de
