| 0-0.031373|from to |
|0.972549-1.003922|from to |
|1.976471-2.007843|from to |
|2.980392-3.011765|from to |
|3.984314-4.015686|from to |
|4.988235-5.019608|from to |
|5.992157-6.023529|from to |
|6.996078-7.027451|from to |
| 7.968627-8|from to |
| *|no data
I don't understand what the error message means (in red color in the console) ?
You need to specify the range option as range=0,8 (instead of range=0-8 as you did).
Stefan
-----Original Message-----
From: grass-user <grass-user-bounces@lists.osgeo.org> On Behalf Of Frank David
Sent: fredag 12. oktober 2018 14:24
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] r.category
Hello grass users,
I have an error message in the console when I open some rasters with witch I've done a r.category.
"Failed to run command 'd.legend
raster=ZVT_nac_projet_hoht2__BDalti75_a1_8_sum@derval title=nacelle color=white range=0-8 at=5.0,50.0,6.9,9.9 thin=3'. Details:
ERROR: Option <range> must be provided in multiples of 2
You provided 1 item(s): 0-8"
| 0-0.031373|from
to |
to |
to |
to |
to |
to |
to |
to |
| 7.968627-8|from
to |
| *|no data
console) ?
Thanks for your reply. But I did not use cat=range option. I only do r.category map=mymap separator=“:” rules=rulefic.txt
with rulefic.txt like :
0:none
1:1 to 2
2:1 to 2
3:3 to 4
4:3 to 4
5:5 to 6
Is something missing ?
Thanks
Le 12/10/2018 à 15:02, Stefan Blumentrath a écrit :
Hi Frank,
Stefan
From: grass-user [<grass-user-bounces@lists.osgeo.org>](mailto:grass-user-bounces@lists.osgeo.org) On Behalf Of Frank David
To: [grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
Hello grass users,
a r.describe display :
* 0.000000-0.031373 0.972549-1.003922 1.976471-2.007843 2.980392-3.011765
3.984314-4.015686 4.956863-4.988235 5.960784-5.992157 6.964706-6.996078
7.968627-8.000000
r.report display :
| 0-0.031373|from
to |
to |
to |
to |
to |
to |
to |
to |
| 7.968627-8|from
to |
| *|no data
console) ?
Thank your for your help !
Frank
grass-user mailing list
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
The error message you sent is related to d.legend module, which you may have called from the graphical user interface, more particular the map window, in order to add a legend to a map display.
If you have a visible legend in your map display, double click it in order to change the range parameter. That should fix the error message.
Ha yes ! a small part of the legend is displayed on the bottom of my map (I did not take care). I had probably activate d.legend by the past to test it.
But I don’t know how to remove it ?
Frank
Le 12/10/2018 à 16:24, Stefan Blumentrath a écrit :
Hi Frank,
* Frank David <frank.david@geophom.fr> [2018-10-12 16:31:06 +0200]:
But I don't know how to remove it ?
Right click on it, then "Remove legend".
Nikos
Thank you Nikos, I succed to remove visible legend on several maps, but it does not solve my problem !...
