[GRASS-user] r.contour generates no lines
I tried to create contours from a DEM with the following information:
| Type of Map: raster Number of Categories: 255
| Data Type: FCELL
| Rows: 9856
| Columns: 4844
| Total Cells: 47742464
| Projection: Transverse Mercator
| N: -3704977.57894189 S: -3803537.57894189 Res: 10
| E: -15589.63705055 W: -64029.63705055 Res: 10
| Range of data: min = -39.681747 max = 1084.584839
The command I used was:
r.contour --overwrite input=ct_dem_10m@PERMANENT
output=ct_contours_100m@PERMANENT step=100 cut=2000
However, the resulting vector file contains no lines. This is the
output of v.info:
| Type of Map: vector (level: 2)
| Number of points: 0 Number of areas: 0
| Number of lines: 0 Number of islands: 0
| Number of boundaries: 0 Number of faces: 0
| Number of centroids: 0 Number of kernels: 0
| Map is 3D: Yes
| Number of dblinks: 1
| N: 0 S: 0
| E: 0 W: 0
| B: 0 T: 0
The attribute table does contain 10 categories starting from 100m and
ending at 1000m.
Leaving out the cut parameter doesn't change anything.
Any ideas about why the file contains no features?
Thanks
Hanlie
On Fri, May 7, 2010 at 1:53 PM, Hanlie Pretorius
<hanlie.pretorius@gmail.com> wrote:
| Data Type: FCELL
| Rows: 9856
| Columns: 4844
output of v.info:
please check if the current region (g.region -p) matches the map
or a subset.
