Hi everyone,
I have a problem on output raster map of cumulative cost when running the r.cost.rast algorithm. the resolution of Output raster is 5 m. Or the resolution of my input raster ( cost raster and raster of starting points) is 1 m.
I cannot figure out how the resolution can be diffrent form input to output
Paul QUERE
Chef de projet en géomatique/Géomaticien
tel: 07 86 18 44 65
paul.quere2@gmail.com
LinkedIn
On Tue, Feb 17, 2015 at 6:36 PM, Paul Quéré <paul.quere2@gmail.com> wrote:
Hi everyone,
is 1 m.
The resolution doesn't depend on the input, rather the computational extent
and resolution must be set using g.region module:
http://grass.osgeo.org/grass70/manuals/g.region.html
so for example if you want to set the extent and resolution based on a
raster map 'my_input_raster' you use (-p is for printing resulting region):
g.region raster=my_input_raster -p
Anna
* Paul QUERE*
tel: 07 86 18 44 65
LinkedIn
<https://www.linkedin.com/profile/view?id=211987275&trk=nav_responsive_tab_profile_pic>
grass-user mailing list
grass-user@lists.osgeo.org
