[GRASS-user] r.diversity (r.li) options on windows
Hi there,
As part of a master's thesis, we would like to use r.diversity to process aerial multi-spectral imagery using a Windows 7 machine.
(The most recent piece of info is apparently this grass-devel thread:
http://article.gmane.org/gmane.comp.gis.grass.devel/56124
Putting Luca and Alessandro in copy because of this related thread:
http://article.gmane.org/gmane.comp.gis.gfoss.italian/12245
As the r.li suite appears still broken on Windows,
http://grasswiki.osgeo.org/wiki/WinGRASS_Current_Status#Known_Issues
we were wondering whether it would be wiser to go the g.gui.rlisetup way
http://grass.osgeo.org/grass70/manuals/g.gui.rlisetup.html
or to opt for a virtual machine installation, e.g.
http://live.osgeo.org/en/quickstart/virtualization_quickstart.html
In general, is there any advantage in using grass 7 vs. 6 in our case?
Kind regards and thanks for any pointer,
Luigi
Hello,
replying to myself to report an attempt at running r.diversity using the virtual machine option, i.e. osgeo-live-vm-7.0 on windows 7 installed as shown at
In GRASS 6.4.3, settings -> Addons estensions -> Install extension from addons [g.extension];
fetched repository (http://svn.osgeo.org/grass/grass-addons/grass6) via "Fetch" button;
selected raster -> r.diversity, and pressed "Install" butto;
received the following output message at GUI command console:
g.extension.py extension=r.diversity svnurl=http://svn.osgeo.org/grass/grass-addons/grass6
Fetching <r.diversity> from GRASS-Addons SVN (be patient)...
svn: Can't move 'r.diversity/.svn/tmp/entries' to
'r.diversity/.svn/entries': File exists
ERROR: GRASS Addons <r.diversity> not found
(Fri Feb 21 15:51:11 2014) Command finished (15 sec)
Is there a way to do a GUI install or, as suggested in the g.extension help page, one should just copy the r.diversity.py script to the grass addons directory (e.g., /grassdata/addons/scripts/)?
Thanks for any pointer,
Luigi
-----Original Message-----
Sent: Tue, 28 Jan 2014 12:58:59 +0100
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] r.diversity (r.li) options on windows
Hi there,
Luigi
grass-user mailing list
____________________________________________________________
Receive Notifications of Incoming Messages
Easily monitor multiple email accounts & access them with a click.
Visit http://www.inbox.com/notifier and check it out!
Hi Luigi,
over the past few weeks Markus Metz has submitted a major rewrite of
r.li.* to GRASS GIS 7.svn.
We tested the older version a lot which is containing a lot of errors.
Suggestion: get a fresh GRASS 7 from SVN (or precompiled, see
http://grass.osgeo.org/grass7/
) and use the r.diversity Addon for GRASS 7.
Backporting the r.li.* rewrite is quite some effort, not sure how to
deal with that.
Best
Hi Markus,
Thanks to you and Markus Metz!
We will immediately go after your suggestion and report back ASAP.
Kind regards,
Luigi
Sent: Sun, 23 Feb 2014 23:51:38 +0100
To: lponti@inbox.com
Subject: Re: [GRASS-user] r.diversity (r.li) options on windows
Hi Luigi,
deal with that.
Best
FREE 3D EARTH SCREENSAVER - Watch the Earth right on your desktop!
Check it out at http://www.inbox.com/earth
Hi Markus,
I have installed grass70 on a virtualBox with OSGeo Live 7.0
GRASS precompiled version from:
https://launchpad.net/~grass/+archive/grass-devel
ppa:grass/grass-devel
Installed precompiled version:
7.0.0+0ubuntu3~develppa~2~svn-30128~ubuntu12.04.1
which the repository says is 9 hrs hold, and hence I assume includes r.li.* updates by Markus Metz.
Start GRASS from terminal with grass70 is fine.
If I go menuwise in wxpython gui:
Settings > Addons extenstions > install extensions from Addons
g.extension gui reports the following error:
Unable to load extensions
and when trying to fecth extensions, the same occurs.
Other things appear not to work properly. For example, again in the gui:
Help > About GRASS GIS
Nothing happens and commmand console reports the following:
  File "/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/lib/agw/customtreectrl.py",
line 6469, in OnKeyDown
id = self.FindItem(self._current, self._findPrefix + ch)
line 4151, in FindItem
id = self.GetNext(id)
line 4036, in GetNext
children = i.GetChildren()
AttributeError
'NoneType' object has no attribute 'GetChildren'
AttributeError
AttributeError
line 6300, in OnKeyDown
if not self.IsItemEnabled(self._current):
line 2661, in IsItemEnabled
return item.IsEnabled()
AttributeError
'NoneType' object has no attribute 'IsEnabled'
AttributeError
AttributeError
AttributeError
  File "/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py",
line 1003, in OnAboutGRASS
win = AboutWindow(self)
  File
"/usr/lib/grass70/etc/gui/wxpython/gui_core/ghelp.py", line
57, in __init__
for title, win in ((_("Info"), self._pageInfo()),
  File
112, in _pageInfo
label = 'GRASS GIS ' + vInfo['version'] + '\n')
KeyError
'version'
Sounds like a Python problem but I am not sure how to deal with that. I also have of course GRASS 6.4.3 intalled as it comes with OSGeo Live 7.0.
Thanks in advance for any pointer.
Kind regards,
Luigi
Hi Luigi,
deal with that.
Best
Protect your computer files with professional cloud backup.
Get PCRx Backup and upload unlimited files automatically.
Learn more at http://backup.pcrx.com/mail
On Fri, Mar 7, 2014 at 4:01 AM, Luigi Ponti <lponti@inbox.com> wrote:
Hi Markus,
File “/usr/lib/python2.7/dist-
packages/wx-2.8-gtk2-unicode/wx/lib/agw/customtreectrl.py”,
AttributeError
‘NoneType’ object has no attribute ‘GetChildren’
This part of error is not related and I fixed it in r59209.
File “/usr/lib/grass70/etc/gui/wxpython/lmgr/frame.py”,
File
“/usr/lib/grass70/etc/gui/wxpython/gui_core/ghelp.py”, line
57, in init
for title, win in ((_(“Info”), self._pageInfo()),
File
112, in _pageInfo
label = 'GRASS GIS ’ + vInfo[‘version’] + ‘\n’)
KeyError
‘version’
This looks like g.version segfaults. What happens when you run:
g.version -rge
Best,
Anna
Kind regards,
Luigi
Hi Luigi,
deal with that.
Best
Hi Anna,
Sent: Fri, 7 Mar 2014 08:42:21 -0500
Then I will have to try compilation from source a bit harder. I have failed so far – interesting that I was able to compile GRASS from source on windows 7 some time ago using OSGeo4W, likely because there are fewer degrees of freedom compared to Linux.
File
57, in init
File
112, in _pageInfo
KeyError
‘version’
g.version -rge
Here is what happens (in GRASS prompt):
g.version -rge
version=7.0.svn
date=2014
revision=
build_date=2014-03-04
Segmentation fault (core dumped)
That’s it. Kind regards and thank you,
Luigi
Dear Anna,
Just compiled from source r59347 and the error triggered by menu command
no longer shows up, i.e., we get the regular gui window showing info (even though Code Revision and Build Date are not available and a question mark is shown instead).
Your suggested test command shows the following ouput:
GRASS 7.0.svn (valdagri):/usr > g.version -rge
version=7.0.svn
date=2014
revision=
build_date=2014-03-26
build_platform=i686-pc-linux-gnu
with revision number still not available.
Our original target, g.extension (see email subject), still returns the Fetch & Install extension from GRASS Addons gui windows with error saying “Unable to load extensions”.
Displaying GIS layers seems to work fine. Basic things like g.region, r.info, etc. also appear to be OK.
We would be grateful if someone can drop a line pointing us to a way to run r.diversity and/or any other comment you might thing useful.
Kind regards,
Luigi
Hi Luigi,
On Sun, Feb 23, 2014 at 11:51 PM, Markus Neteler <neteler@osgeo.org> wrote:
Hi Luigi,
I have backported it all to GRASS 6.4.svn and 6.5.svn.
Greetings from the Vienna Code Sprint,
Dear Markus,
That's great! Thanks! Will give it a try right away.
Enjoy Vienna,
Luigi
On 26/03/2014 15:47, Markus Neteler wrote:
Hi Luigi,
Hi Luigi,
