[GRASS-user] r.fuzzy.system: specifying raster file?
I'm trying to run the r.fuzzy.system module - have created the map and rules
files, but can't seem to find where to specify the input raster file in the
r.fuzzy.system gui window. I can select the .map, and .rul file, but there
doesn't seem to be a field for the input raster file. As indicated on
running the extenion:
ERROR: Raster map <mti> not found
Also tried adding 'input=filename' and running from the command line but:
Sorry, <input> is not a valid parameter
I guess that that the input raster file needs to be specified in the .map
file, but I'd be grateful for any advice on the syntax needed to specify. My
flood.map file contains the following:
%mti
$ low {right; -1,3; sshaped; 0; 1}
$ moderate-low {both; -1,3,4,5; sshaped; 0; 1}
$ moderate-high {both; 4,5,11,14; sshaped; 0; 1}
$ high {left; 11,14; sshaped; 0; 1}
My rules file:
$ low {mti = low}
$ moderate-low {mti = moderate-low}
$ moderate-high {mti = moderate-high}
$ high {mti = high}
Refs:
https://svn.osgeo.org/grass/grass-addons/grass6/raster/r.fuzzy.system/description.html
gama.fsv.cvut.cz/data/geoinformatics/2011/05-20/10-dileo.pdf
Richard
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-fuzzy-system-specifying-raster-file-tp5057685.html
Replacing '%mti' with '%actualfilename' gets me a bit further, but I also
need to include the definition of the output file in the .map file:
ERROR: No defininition for output map: <watershed_flood_fuzzy> in map file
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-fuzzy-system-specifying-raster-file-tp5057685p5057687.html
On Tue, Jun 4, 2013 at 11:09 AM, RichardC <richtcooper@hotmail.com> wrote:
... these you find in the "Required" tab.
but there
While I am not familiar with the module, I understand from the manual that
the input map(s) are specified in the ASCII input file
I guess that that the input raster file needs to be specified in the .map file,
Yes, I also think so.
%mti
My rules file:
$ low {mti = low}
$ high {mti = high}
Refs:
The related source code snippet is (I think):
map_parser.c:
        if (*buf == '%') {
            fgetpos(fd, &position);
            sscanf(buf, "%[^\n]", map);
            char_strip(map, '%');
            G_strip(map);
            mapset = (STRING) G_find_raster2(map, "");
So the word after % might be taken as map name as seen for example in
http://trac.osgeo.org/grass/browser/grass-addons/grass7/raster/r.fuzzy/r.fuzzy.system/flood.map
Perhaps the author can help to explain/confirm?
Although I am not the author of that module, I can confirm that the input raster files are specified in the .map file as explained in the example.
I’m trying to run the r.fuzzy.system module - have created the map and rules
files, but can’t seem to find where to specify the input raster file in the
… these you find in the “Required” tab.
but there
doesn’t seem to be a field for the input raster file.
but I’d be grateful for any advice on the syntax needed to specify. My
%mti
My rules file:
$ low {mti = low}
$ high {mti = high}
Refs:
map_parser.c:
if (*buf == ‘%’) {
sscanf(buf, “%[^\n]”, map);
char_strip(map, ‘%’);
G_strip(map);
mapset = (STRING) G_find_raster2(map, “”);
grass-user mailing list
grass-user@lists.osgeo.org
I am experiencing a similar problem. I have followed the steps as in the
example, making sure all the maps are in the search path but
r.fuzzy.system keeps reporting an error regardless of the map specified:
My input map definition in the .map file:
%elevation
$nlow{left; -3,-2; linear; 0; 1}
$scar{both; -3,-2,0,2; linear; 0; 1}
$nhigh{right;0,2; linear; 0; 1}
Reported Error:
"Illegal filename. Character <
not allowed.
ERROR: Raster map
<elevation
not found"
I have also tried to specify the mapset using "@" as explained in the
example, still the same error regardless of the map (and respective
mapset)
%elevation@PERMANENT
Reported Error:
not allowed.
ERROR: Raster map
&lt;
elevation@PERMANENT
&gt;
not found"
I will be grateful for any advice in finding out the source of this error
and how to rectify it.
Beatrice.
On Mon, Jun 17, 2013 at 9:41 AM, Markus Neteler &lt;
neteler@
&gt; wrote:
On Tue, Jun 4, 2013 at 11:09 AM, RichardC &lt;
richtcooper@
&gt; wrote:
> Hi,
rules
the
> but there
that
.map file,
> %mti
> My rules file:
> $ low {mti = low}
> $ high {mti = high}
> Refs:
map_parser.c:
        if (*buf == '%') {
            G_strip(map);
grass-user@.osgeo
grass-user@.osgeo
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-fuzzy-system-specifying-raster-file-tp5057685p5066892.html
example, making sure all the maps are in the search path but r.fuzzy.system
%elevation
Reported Error:
not allowed.
ERROR: Raster map
<elevation
not found&quot;
I have also tried to specify the mapset using &quot;@&quot; as explained in
the example, still the same error regardless of the map (and respective
mapset)
Reported Error:
&quot;Illegal filename. Character &lt;
not allowed.
ERROR: Raster map
<elevation@PERMANENT
not found"
Beatrice.
View this message in context: http://osgeo-org.1560.x6.nabble.com/r-fuzzy-system-specifying-raster-file-tp5057685p5067435.html
Hi Beatrice,
I traced down your problem(s) with your files for r.fuzzy.system. First, thank you for the minimal examples. That were great for tracing the problem.
So there were three problems:
  1. you defined two output levels (res1 and res2) in your .MAP file but you used different levels in your .RUL file (rul1 and rul2)
  2. you did not include the shape factor (e.g. “linear”) in the definiton of your output classes
  3. And the real problem that caused all your problems were the line endings. You’re probably working on Windows and the Windows text editor you used for creating your files have by default a different definition of a “new line”. This is different to Linux line endings. Common simple texteditors do not show which line endings are in use so it is really difficult for a user to realize that there are different line endings (I had the same problems some months/years ago). So what I did: I am using now TextWrangler on my Mac as text editor of my choice. This program and probably many others (also for Windows) allow to change the definition of the line endings to Unix-like “newlines”. Just change that and than your fuzzy system will work smoothly (tested with GRASS6.5 so there is no need to run r.fuzzy.system in GRASS7)…
/Johannes
On Mon, Aug 19, 2013 at 2:11 PM, Beatrice Christopher Tarimo <beatrice.tarimo@umb.no> wrote:
Dear Johannes,
I am sorry I could not provide you with feedback as promised in my last email. I have been experiencing problems running GRASS 7. I now have it running but I have not been able to install extensions/addons. It reports an error: “unable to load extensions”. I am trying to figure out what I am not doing right and will provide you with feedback as soon as I manage to test r.fuzzy.system on GRASS 7.
Thank you.
With kind regards,
Beatrice.
Sent: 16 August 2013 16:23
To: Johannes Radinger
Subject: RE: FW: [GRASS-user] r.fuzzy.system: specifying raster file?
Hi Johannes,
Thank you for your email and this information.
I have been running GRASS 6.4.2 and GRASS 6.4.3RC2. I will try with GRASS 7.0 and will provide you with feedback as soon as possible, hopefully before next week.
Thank you very much for your help.
Best regards,
Beatrice.
From: Johannes Radinger [johannesradinger@gmail.com]
Sent: 16 August 2013 15:20
To: Beatrice Christopher Tarimo
Subject: Re: FW: [GRASS-user] r.fuzzy.system: specifying raster file?
Hi again…
which version of GRASS are you using at the moment? I know that I had some problems with the 6.X version, thus all my work is done with GRASS 7.0. So maybe you can try it with GRASS 7.0 and see if that already solves your problem.
Anyway I can have a look at your minimal example you provided next week on my GRASS 7 machine.
Best regards,
Johannes
On Fri, Aug 16, 2013 at 11:12 AM, Johannes Radinger <johannesradinger@gmail.com> wrote:
As my server with GRASS is down at the moment I can’t check your example. Hopefully I can manage it by next week. I hope thats not too late.
Best regards,
Johannes
On Fri, Aug 16, 2013 at 10:34 AM, Beatrice Christopher Tarimo <beatrice.tarimo@umb.no> wrote:
Dear Johannes,
I am sorry for any inconvenience this email might cause but I wish to ask if you managed to have some time to look into the error with regards to r.fuzzy.system as per our previous communication.
Thank you,
Beatrice.
Sent: 31 July 2013 22:10
Hi Johannes,
Thank you for your email. Please allow me to wait until around this date.
Thank you so very much for your help.
Best regards,
Beatrice.
Sent: 31 July 2013 14:44
Thank you Beatrice for your working example. At the moment I have no time for testing my self and will be away for a conference next week. So most probably I can look into your data earliest on the 12 of august. If you your request is more urgent you can try to post the working example for the NC dataset to the GRASS user mailing list. Maybe someone else has also experience with r.fuzzy and can try your example.
best regards
Johannes
On Tue, Jul 30, 2013 at 7:59 AM, Beatrice Christopher Tarimo <beatrice.tarimo@umb.no> wrote:
Hi Johannes,
The problem still persist. I did work in one mapset with all the input maps in this mapset, simple map names and only two input maps. The raster maps “B3/B4/B7” were imported by r.in.gdal and “ndii” is an index of these other maps computed by r.mapcalc. My .map file is similar to the one I sent to you with relevant input map names and fuzzy sets definitions.
These are the maps in my mapset:
g.list rast
raster files available in mapset :
B3 B4 B7 ndii
(Mon Jul 29 23:25:45 2013) Command finished (0 sec)
Error message from r.fuzzy.system:
not allowed.
ERROR: Raster map <B4
not found
Same error message for a different input map
not allowed.
ERROR: Raster map <ndii
not found
I am attaching very simplified .map and .rul files that use GRASS North Carolina dataset in the landsat mapset. I use file names as they are here but I tried with simple map names and got the same error message.
r.fuzzy.system maps=D:\Beatrice\GRASS\grassdata\nc_spm_08\landsat\Maps.map.txt rules=D:\Beatrice\GRASS\grassdata\nc_spm_08\landsat\Rules.rul.txt family=Zadeh imp=minimum res=100 output=test1
not allowed.
ERROR: Raster map <lsat5_1987_40
not found
Thank you very much for your help,
Best regards,
Beatrice.
Sent: 29 July 2013 09:15
thank you for the information. From a first view, I don’t see any major errors in you files.
However, to trace your problem I’d suggest to work only in one mapset and have all maps that are specified in the map-file in that mapset. Than you can also skip the trailing “@PERMANENT”. Furthermore I’d suggest to use only three or even only two maps for testing your fuzzy-approach and maybe rename the maps for the testing to very simple names without any special characters (e.g. “test1”, “test2”). Maybe this already indicates where the error is located.
Otherwise you could also try to create a minimum test example with one of the standard locations (e.g. the GRASS North carlolina dataset) to see if the problem also occurs there (which might than be a problem with the module itsel). Such an minimum testing example can also be useful for other GRASS users to reproduce the error and help tracing the problem.
So overall, my tip is to simplify your fuzzy procedure stepwise to better identify your problem.
Best regards,
Johannes
On Sun, Jul 28, 2013 at 10:04 PM, Beatrice Christopher Tarimo <beatrice.tarimo@umb.no> wrote:
Hi Johannes,
Thank you very much for your reply. Please find attached my .map file. Below is the result of g.list of my mapset:
(Sun Jul 28 21:33:34 2013)
g.list rast
diff ndii ndii2_abs ndii3 sum
index ndii2 ndii2asciirast ndvi2
L5171065_06520110726_B20 L5171065_06520110726_B50 clusters
L5171065_06520110726_B30 L5171065_06520110726_B60 ndvi
L5171065_06520110726_B40 L5171065_06520110726_B70
(Sun Jul 28 21:33:34 2013) Command finished (0 sec)
No. I am not working in the PERMANENT mapset but I have some of my data in the PERMANENT mapset. I have tried with data stored in a different mapset, I have also to work in the PERMANENT mapset, I get the same error. I have also tried with mapsets (and datasets) coming with GRASS to check if the problem is my mapsets (or my datasets) but r.fuzzy.system returns the same error.
Thank you.
Best regards,
Beatrice.
Sent: 26 July 2013 09:12
Hi Beatrice,
have you checked if there are any trailing spaces after your map name in the .map file?
Maybe you can post the .map file as it is and the result of g.list of your mapset.
Are you working in the PERMANENT mapset?
Best regards,
Johannes
On Thu, Jul 25, 2013 at 9:52 PM, Beatrice Christopher Tarimo <beatrice.tarimo@umb.no> wrote:
Dear Johannes Radinger,
I am writing to request your help on the problem explained below with regards to r.fuzzy.system in GRASS GIS. I posted this on GRASS-user forum and also wrote to the person who wrote the first post on this error but have not received any replies as yet. Could you please help me?
I am sorry for any inconvenience.
Thank you and best regards,
Beatrice.
From: neteler.osgeo@gmail.com [neteler.osgeo@gmail.com] on behalf of Markus Neteler [neteler@osgeo.org]
Sent: 25 July 2013 15:04
Subject: Re: [GRASS-user] r.fuzzy.system: specifying raster file?
Hi Beatrice,
perhaps you could contact Johannes Radinger
(johannesradinger@gmail.com) for this, since he already used the module.
Please let me then know of manual improvements to be done.
Best
On Thu, Jul 18, 2013 at 8:56 PM, Beatrice <beatrice.tarimo@umb.no> wrote:
%elevation
Reported Error:
not allowed.
ERROR: Raster map
<elevation
not found"
mapset)
Reported Error:
not allowed.
ERROR: Raster map
not found"
Beatrice.
Hi Markus,
Here is a copy to the list for g.extension installer in GRASS 7.0.
Best regards,
Beatrice.
On Mon, Aug 19, 2013 at 2:11 PM, Beatrice Christopher Tarimo <[hidden email]> wrote:
Dear Johannes,
Thank you.
With kind regards,
Beatrice.
Hi Johannes,
Best regards,
Beatrice.
Hi again…
Best regards,
Johannes
Best regards,
Johannes
On Fri, Aug 16, 2013 at 10:34 AM, Beatrice Christopher Tarimo <[hidden email]> wrote:
Dear Johannes,
Thank you,
Beatrice.
Hi Johannes,
Best regards,
Beatrice.
best regards
Johannes
On Tue, Jul 30, 2013 at 7:59 AM, Beatrice Christopher Tarimo <[hidden email]> wrote:
Hi Johannes,
g.list rast
B3 B4 B7 ndii
not allowed.
not found
not allowed.
not found
not allowed.
not found
Best regards,
Beatrice.
Best regards,
Johannes
On Sun, Jul 28, 2013 at 10:04 PM, Beatrice Christopher Tarimo <[hidden email]> wrote:
Hi Johannes,
g.list rast
L5171065_
L5171065_
Thank you.
Best regards,
Beatrice.
Hi Beatrice,
Best regards,
Johannes
On Thu, Jul 25, 2013 at 9:52 PM, Beatrice Christopher Tarimo <[hidden email]> wrote:
Beatrice.
From: [hidden email] [[hidden email]] on behalf of Markus Neteler [[hidden email]]
Hi Beatrice,
([hidden email]) for this, since he already used the module.
Best
On Thu, Jul 18, 2013 at 8:56 PM, Beatrice <[hidden email]> wrote:
%elevation
Reported Error:
not allowed.
ERROR: Raster map
<elevation
not found"
mapset)
Reported Error:
not allowed.
ERROR: Raster map
not found"
Beatrice.
[hidden email]
(reducing msg to the essential part)
On Tue, Aug 20, 2013 at 8:19 AM, Beatrice Christopher Tarimo
I have also successfully tested r.fuzzy.system on GRASS 7.0. I think the
error with addons happens when using the menu option (Settings - Addons
extensions ....). Running g.extensions from the command console does not
report successful installation but provide a Traceback which in the end
reports
File "C:\Program Files (x86)\GRASS GIS 7.0.svn\Python27\lib\zipfile.py", line 807, in
_RealGetContents
    raise BadZipfile, "File is not a zip file"
zipfile.BadZipfile: File is not a zip file
Afterwards, the Addons of interest is/are available e.g when called from the
command console.
Please tell us when you downloaded winGRASS7 - there were significant wxGUI
changes recently. To get the version number:
g.version -g
Best
I am now running a version which I downloaded yesterday, 19 Aug 2013, (g.version -g results shown below). I have checked, the GUI (Settings -> Addon extensions -> Install extensions from addons) still reports "unable to load extensions". The command line reports successful installation, atleast for the one Addon i have tested.
g.version -g
version=7.0.svn
date=2013
revision=57466
build_date=2013-08-18
Beatrice.
________________________________________
Sent: 20 August 2013 10:39
Cc: GRASS user list
Subject: Re: FW: FW: r.fuzzy.system: specifying raster file?
g.version -g
Best
