[GRASS-user] r.grow.distance can't create meters instead of map units
Hello everyone
My first post in this list,
So i am trying to create a raster with r.grow.distance. If i use the normal options everything works like the proximity analysis of QGIS, but when I try to add the advanced parameter Output distances in meters instead of map units i get the error “ERROR: Output distance in meters for lat/lon is only possible with ‘metric=geodesic’”
How do i add in the metrics the geodesic? I only have 4 euclidean,manhattan,squared,maximum.
Is there any alternative to create the raster in meters instead of map units?
Kind regards
Dimitris
Hi Dimitris,
On Fri, Aug 2, 2019 at 8:58 AM Dimitris sal <jimmaras123@gmail.com> wrote:
Hello everyone
As you are working via QGIS, in which projection do you work?
If i use the normal options everything works like the proximity analysis of QGIS, but when I try to add the advanced parameter Output distances in meters instead of map units i get the error "ERROR: Output distance in meters for lat/lon is only possible with 'metric=geodesic'"
Yes, this is a limitation in QGIS processing (for whatever reason).
The parameters made available to the QGIS users are often a subset of
those provided by GRASS GIS.
# QGIS processing
grep Metric /usr/share/qgis/python/plugins/processing/algs/grass7/description/r.grow.distance.txt
QgsProcessingParameterEnum|metric|Metric|euclidean;squared;maximum;manhattan|False|0|True
# GRASS GIS
r.grow.distance --help
   metric Metric
             options: euclidean,squared,maximum,manhattan,geodesic
             default: euclidean
The change would be needed here:
https://github.com/qgis/QGIS/blob/release-3_8/python/plugins/processing/algs/grass7/description/r.grow.distance.txt
As a local workaround, you can simply search for r.grow.distance.txt
on your computer and add the missing "geodesic" there.
(and open an issue with the QGIS project or open a pull request with
the change there, or someone else does that).
Best,
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
Hello
In order to fix it I had to enable the GRASS plugin (is already installed) then import the raster , and run the plugin’s r.grow.distance with geodesic and it worked.
I just tried this and it worked Thanks for your help!!!
on your computer and add the missing “geodesic” there.
Kind regards
Dimitris
Στις Παρ, 2 Αυγ 2019 στις 12:53 μ.μ., ο/η Markus Neteler <neteler@osgeo.org> έγραψε:
Hi Dimitris,
Hello everyone
QGIS processing
metric Metric
default: euclidean
Best,
Markus Neteler, PhD
