[GRASS-user] r.horizon and negative tilt
Dear all,
It seems that r.horizon in does not return negative heights. How it's possible in case of the given point from the calculation is done is located on mountain and the horizon around is below zero ??. I miss something may be...
Thank you for your explanations
Regards
Frank
Hi Frank,
just my opinion but r.horizon I suppose is targeted to solar radiation modules and because of that returns only the line-of-sight "obstacles" above the ground plane, where direct sunlight may be obstructed by obstacles.
best regards,
Andrea Balotti
Il 28/07/2018 15:59, Frank David ha scritto:
Dear all,
Regards
Frank
grass-user mailing list
grass-user@lists.osgeo.org
Hi Andrea,
Thanks for your message. But what is the ground plane ? r.horizon use the topography, so nothing is plane (and the earth curvature tends to lower the ground). I guess as the calculation is done at ground level, the minimum viewable horizon cannot be lower than zero. The calculation should be done higher than ground level to “see” negatives horizon. Never mind I will try to create my own r.horizon with r.transect or r.profile.
Best regards,
Frank
Le 30/07/2018 à 08:47, balotti.and@gmail.com a écrit :
Hi Frank,
just my opinion but r.horizon I suppose is targeted to solar radiation modules and because of that returns only the line-of-sight “obstacles” above the ground plane, where direct sunlight may be obstructed by obstacles.
best regards,
Andrea Balotti
Dear all,
It seems that r.horizon in does not return negative heights. How it’s possible in case of the given point from the calculation is done is located on mountain and the horizon around is below zero ??. I miss something may be…
Regards
Frank
Hi Andrea,
Yes, what you explain below is what I mean with “ground plane”.
Have you taken a look to r.viewshed? I never tried it but maybe is useful for your purposes.
Best regards,
Frank
Best regards,
Hi Frank,
best regards,
Andrea Balotti
Dear all,
Regards
Frank
Ho yes, why not. I could use r.viewshed to find the farest part of the topography able to see my point and get it’s angle mode. The trick to find is how to get that cell ?
Best regards,
frank
Le 30/07/2018 à 11:18, balotti.and@gmail.com a écrit :
Il 30/07/2018 09:24, Frank David ha scritto:
Hi Andrea,
Best regards,
Frank
Best regards,
[grass-user@lists.osgeo.org](mailto:grass-user@lists.osgeo.org)
[https://lists.osgeo.org/mailman/listinfo/grass-user](https://lists.osgeo.org/mailman/listinfo/grass-user)
Hi Frank,
best regards,
Andrea Balotti
Dear all,
Regards
Frank
On Sat, Jul 28, 2018 at 3:59 PM, Frank David <frank.david@geophom.fr> wrote:
Dear all,
r.horizon is indeed ignoring points that are lower than the given point, see
https://trac.osgeo.org/grass/browser/grass/trunk/raster/r.horizon/main.c#L1037
and following lines
I agree that this behaviour is questionable
Markus M
Regards
Frank
Hello Markus,
is it possible to add an option to evaluate the negatives hight in a future release ? (I don’t know C)
Best regards,
Frank
Dear all,
and following lines
Markus M
Regards
Frank
Frank,
Some years ago I wrote a module (also called r.horizon) which I think does what you want. I never got around to formally contributing it (must compare with the existing r.horizon and do so some time). Anyhow, have updated for GRASS 7 and will send you the code direct - it compiles as r.horizon2 to avoid collision with the existing module.
Mark
Frank David <frank.david@geophom.fr> writes:
topography able to see my point and get it's angle mode. The trick to
Best regards,
frank
Hi Andrea,
lower the ground).
Yes, what you explain below is what I mean with "ground plane".
done higher than ground level to "see" negatives horizon.
r.profile.
Best regards,
Frank
Best regards,
Le 30/07/2018 à 08:47, balotti.and@gmail.com a écrit:
Hi Frank,
best regards,
Andrea Balotti
Dear all,
Regards
Frank
Dr Mark Lake
Senior Lecturer in Archaeology
UCL Institute of Archaeology
31-34 Gordon Square
London WC1H 0PY
UK
Tel: +44 (0)207 679 7495
Fax: +44 (0)207 383 2572
Dear Mark,
El vie., 3 ago. 2018 a las 19:05, Mark Lake (<mark.lake@ucl.ac.uk>) escribió:
Frank,
so some time).
yes! please do :slight_smile:
Vero
On Mon, Jul 30, 2018 at 4:55 PM, Frank David <frank.david@geophom.fr> wrote:
Hello Markus,
Please try trunk r73049. Negative angles are now allowed by default.
Markus M
Best regards,
Frank
Dear all,
and following lines
Markus M
Regards
Frank
